Members Lil Doodler Posted June 14, 2020 Members Report Posted June 14, 2020 Howdy, thought I'd share an easy to make tool to making it easier to sharpen. The ideal is that you put the stone at the angle, and hold the knife horizontally as you move it. This one I made is adjustable for many different angles. Move the dowel rods to adjust the angle. Use the angle locator to see what your is. Most swivel knives I've seen have an angle of 30 degrees. It's easy to move the different dowel rods in the different holes to get different elevations Quote
Members Lil Doodler Posted June 14, 2020 Author Members Report Posted June 14, 2020 It's made of a couple of pieces of scrap wood, a hinge, dowel rod cut to different lengths and a piece of scrap screwed at the bottom to hold the stone in placw Quote
Members Lil Doodler Posted June 14, 2020 Author Members Report Posted June 14, 2020 Just hold the blade horizontal to be at the proper angle for sharpening or stropping This one is good because you can adjust it to almost any angle used for sharpening. I made a smaller one to use for stropping the swivel knife. I use rouge on a card, put the card on the little block. Quote
Members Lil Doodler Posted June 14, 2020 Author Members Report Posted June 14, 2020 (edited) You can adopt this for other types of stones. If you can cut the wood at the angle you use the most it will be simpler - not adjustable, no hinge or dowel rods. This one is at 20 degrees for kitchen knives Edited June 14, 2020 by Lil Doodler Quote
Members Grumpymann Posted June 14, 2020 Members Report Posted June 14, 2020 Thanks for sharing! Quote
CFM chuck123wapati Posted June 14, 2020 CFM Report Posted June 14, 2020 Now that's a good idea! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Lil Doodler Posted June 14, 2020 Author Members Report Posted June 14, 2020 Oh, I forgot to mention, using this at 15 degrees is excellent for sharpening your head knife. It can be challenging to sharpen the left and right sides at the same angle on a stone that's laying down. Again, just keep the blade horizontal Quote
Members Lil Doodler Posted June 14, 2020 Author Members Report Posted June 14, 2020 (edited) Sharpening the outside Edited June 14, 2020 by Lil Doodler Quote
Members Lil Doodler Posted June 14, 2020 Author Members Report Posted June 14, 2020 That Johnson's pitch and angle locator sells for under $7 at Home Depot and on Amazon Quote
