esantoro Posted September 15, 2007 Report Posted September 15, 2007 I've been having some difficulty getting good-looking stitches when stitching 2 oz suede to the flesh side of 5/6 oz latigo. Top and bottom tension seem to be fine, as neither thread is being pulled to the surface. The top stitches don't seem to lie down nicely. I'm using a size 24 needle and 207 thread. There isn't a problem when I stitch two or more layers of the 5/6 oz latigo, just when I'm stitching the suede lining onto one layer of 5/6 oz. I know that some have said in the past that 207 is too thick a thread for such leather, but this is the size I need when stitching together most of my briefcase parts. I would hate to have to go down to 138 whenever I need to do some of the thinner trim. I may have found the problem but am not sure: Does it seem plausible that a lighter duty, narrower presser foot may be the problem. Today, for the sake of experimentation, I switched to the original much thicker heavy-duty left presser toe that came with the machine, and it seemed to solve all my problems, but I'm not sure why that would make much of a difference. I'll experiment a bit more. Thanks, Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator Art Posted September 16, 2007 Moderator Report Posted September 16, 2007 Hi Ed, When using smaller feet and lighter material it may be necessary to cut back on the presser foot pressure/tension. The bigger foot will have a larger area in contact with the material and can distribute that pressure well, whereas with the smaller foot the area is reduced considerably and the spring is still exerting the same pressure in a smaller area maybe compressing the leather too much or pulling it a bit. If you like the little foot (you are not alone, I don't really love the Artisan foot that came with mine) try backing-off the pressure foot tension screw on top of the machine here: I use this double foot for almost anything and it distributes the pressure quite evenly. I got this from Steve at Artisan at one of the shows. Art I've been having some difficulty getting good-looking stitches when stitching 2 oz suede to the flesh side of 5/6 oz latigo. Top and bottom tension seem to be fine, as neither thread is being pulled to the surface. The top stitches don't seem to lie down nicely.I'm using a size 24 needle and 207 thread. There isn't a problem when I stitch two or more layers of the 5/6 oz latigo, just when I'm stitching the suede lining onto one layer of 5/6 oz. I know that some have said in the past that 207 is too thick a thread for such leather, but this is the size I need when stitching together most of my briefcase parts. I would hate to have to go down to 138 whenever I need to do some of the thinner trim. I may have found the problem but am not sure: Does it seem plausible that a lighter duty, narrower presser foot may be the problem. Today, for the sake of experimentation, I switched to the original much thicker heavy-duty left presser toe that came with the machine, and it seemed to solve all my problems, but I'm not sure why that would make much of a difference. I'll experiment a bit more. Thanks, Ed Quote For heaven's sakes pilgrim, make yourself a strop!
esantoro Posted September 16, 2007 Author Report Posted September 16, 2007 Hi Art, I'll try backing off on the presser foot tension, but I think I already have it backed off quite a bit. I was thinking of uploading pics earlier but was lazy. I'll do it a bit later today. I think that perhaps the narrow presser foot is also made out of a lighter metal than is the one you have. Your's looks as if it is made out of tempered steel, as is the original presser foot that came with the machine. Now what I have set up is the original large left presser toe (I had the right side of the original presser foot cut off) with a narrow center walking foot (it's easier than with the original wide center foot to gauge 1/8" from the edge). But to tell the truth, I think the nicest stitching is with the original toe/foot and original wide center foot for the precise reason you mentioned, more weight/mass distributed onto the leather. By the way, Art, what is that silver knobby thing protruding from your lube something that comes standard or something optional? Mine didn't come with it, and when I use the lube pot, The lubricant gets a bit messy. Thanks, again, for the tutorial, Ed Hi Ed,When using smaller feet and lighter material it may be necessary to cut back on the presser foot pressure/tension. The bigger foot will have a larger area in contact with the material and can distribute that pressure well, whereas with the smaller foot the area is reduced considerably and the spring is still exerting the same pressure in a smaller area maybe compressing the leather too much or pulling it a bit. If you like the little foot (you are not alone, I don't really love the Artisan foot that came with mine) try backing-off the pressure foot tension screw on top of the machine here: I use this double foot for almost anything and it distributes the pressure quite evenly. I got this from Steve at Artisan at one of the shows. Art Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
esantoro Posted September 16, 2007 Author Report Posted September 16, 2007 Here are the pics. Ed Hi Ed,When using smaller feet and lighter material it may be necessary to cut back on the presser foot pressure/tension. The bigger foot will have a larger area in contact with the material and can distribute that pressure well, whereas with the smaller foot the area is reduced considerably and the spring is still exerting the same pressure in a smaller area maybe compressing the leather too much or pulling it a bit. If you like the little foot (you are not alone, I don't really love the Artisan foot that came with mine) try backing-off the pressure foot tension screw on top of the machine here: I use this double foot for almost anything and it distributes the pressure quite evenly. I got this from Steve at Artisan at one of the shows. Art Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator Art Posted September 16, 2007 Moderator Report Posted September 16, 2007 Hi Ed, Them's thread strippers and I use them to remove the excess oil from thread coming out of the lube pot. Size 346 can pull a bunch of lube out with it and it dribbles off the primary thread tension and generally gets all over; and this solves that little problem. I purchased the whole pot from Ferdco and it is for the 441. I had to do a little grinding to get the pot to fit on the bigger 4000P, but it only took about 15 seconds (belt grinders work great). This pot has two strippers in case you want to lube a bobbin without unthreading the primary. You get a much more even thread feed with this setup. Ron might just sell the strippers but the whole setup wasn't that expensive. The Campbell uses a little different setup with some BIG strippers, probably more so because they are the also used for tension, the Campbell uses timing to stop and lock thread when it needs to and these big strippers apply any tension needed to stop any inertial problems. Notice a stripper before the thread goes into the pot and after it comes out. The one out of the pot strips any excess lube. You can buy these parts from Campbell also. Art Hi Art,By the way, Art, what is that silver knobby thing protruding from your lube something that comes standard or something optional? Mine didn't come with it, and when I use the lube pot, The lubricant gets a bit messy. Thanks, again, for the tutorial, Ed Quote For heaven's sakes pilgrim, make yourself a strop!
esantoro Posted November 27, 2007 Author Report Posted November 27, 2007 I'd like to look into getting those thread wipers. How do they connect to the lube pot? Are they glued on, with the hole in the lube pot (where the thread exits) no larger than that shown in the pic of my lube pot, or must one drill a larger hole and secure the wipers somehow? I'd love to find the materials for this thread wiper/squeegee at a hardware or plumbing store, if it's something that can be installed easily. Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator bruce johnson Posted November 27, 2007 Moderator Report Posted November 27, 2007 Ed, A poorman's thread wiper suggestion. I had one of the lube pots like yours. What I did was to cut a 1" cube of dry cellulose sponge, then cut a diagonal slit part way in. Lay it under the thread between the hole in the lid (where the thread exits the pot) and the loopy thread guide to aim it to the primary tensioner. lay the thread in the slit, and its tension with the thread in it, and up against that guide will hold it in place. That 1" cube will strip alot of lube before it gets saturated. Then squeeze it out back into the pot, and cut another cube. You can also wash the sponge cubes in soapy water and let them dry to recycle them. My new lube pot has the wipers, but I still use the sponge. Easier to change thread without tying on and pulling the new thread through. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
esantoro Posted November 28, 2007 Author Report Posted November 28, 2007 Bruce, awesome idea. Thanks. One more thing. I've had about a quarter inch of Lexol in the pot for about three months now and it's beginning to turn red. Does that sound normal? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator Art Posted November 28, 2007 Moderator Report Posted November 28, 2007 Hi Ed, Been using anything but white thread? Art Bruce,awesome idea. Thanks. One more thing. I've had about a quarter inch of Lexol in the pot for about three months now and it's beginning to turn red. Does that sound normal? Ed Quote For heaven's sakes pilgrim, make yourself a strop!
esantoro Posted November 28, 2007 Author Report Posted November 28, 2007 Art, I haven't even been running thread through the pot. The Lexol has just been sitting there. I was under the impression that I could just leave it set there until the time came when I needed to run thread through the pot. Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
