I can use some suggestions of how others treat the corners of this rope edge.....
Thanks!
JOhan
JOhan
****Afrikaans: Leerwerker *****  ****Zulu: lesikhumba isisebenzi  Latvian: ādas darba ņēmējs *****Russian: кожа работника ****English: Leatherworker ****Dutch: Lederbewerker ****Flemish: Leerbewerker ****Hebrew: עור פועל ****German: Leder Handwerker ****Hungarian: Bőrdíszműves ****Turkish: deri işçisi ****French: Artisan du Cuir ****Spanish: Artesano de Cuero ****Norwegian: Skinn kunstners ****Swedish: Läderhantverkare ****Greek: δερμάτινα εργαζόμενος  Sotho: mosebeletsi oa letlalo
Sure wish I could put my hands through the screen and show you.  You were almost there.
But have a look at this:
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • 4 weeks later...
Don't over-run the corner, you can always hand-work the angle. To avoid over-running, over-stamp the last repeat (if if the punch makes 5 twists and you only want 4, back it up so the last twist of the previous punch is covered again. If you're using a clamped-down steel rule to align, then it'll be invisible
