Hi there,
I am currently using a Juki MS-1261, a feed off arm machine with a 1/4 heavyweight lapseam folder. I have absolutely no problem using this machine until it comes to curves and closing the arm to body. With curves, I just think it's practice unless anyone has some top tips for lapseam folders, but the main issue seems to be getting two lapseams to lapseam together under the arm - does anyone have any expierience or tips for this?
Thanks
  • 5 weeks later...
On the curves, the fabric will want to walk out of the folder. Shove more fabric than you think you need into to folder. Lining up your seams takes practice as well. The bottom will want to continue to feed while the top will hesitate. Make sure your presser foot is moving high enough to allow the thickness of the stacked seams. Hold back the bottom ply and don’t pull on the top ply. Lastly, experiment with sliding your folder back just before crossing the seam and with the needles down, lift the presser foot slightly and push the top ply into alignment. It takes practice.
Regards, Eric
Can this machine be fitted with a side feed folder? They work great on inside curves.
Posted IMHO, by Wiz
Unfortunately no, the arm is just wide enough for an inline folder since it has to run inside sleeves. Also, any folder used on these machines should be spring loaded on the top half to allow a previously sewn lapped seam to pass through. Oh, and howdy Wiz.
Regards, Eric
Regards, Eric
Thanks Eric and Welcome Back Cotter!
Posted IMHO, by Wiz
