Members Rylando Posted October 21, 2020 Members Report Posted October 21, 2020 My highlead GC-0618-1SC is having an issue I'll describe as two steps forward one step backwards. When I get to a narrow section of a piece of leather, when the machine goes to walk the leather, it doesn't work quite right and seems to back it up a little bit before going forward and making the next needle hole. It only seems to happen on a narrow section where the leather probably isn't touching the needle plate underneath. The first picture is the underside of the stitch, where it suddenly starts looping on the bottom. The only reason why I can figure it does this, is because the leather doesn't touch the needle plate. Is that the right idea or am I going in the wrong direction? Could this be a tension problem or a mis-adjusted machine? The second picture shows the underside where it sews perfectly and no loops, and the third shows how it loops where it goes to a thin section. Any suggestions on whats happening here and/or how to fix this? Quote
Members Rylando Posted October 21, 2020 Author Members Report Posted October 21, 2020 Forgot to mention: The above pictures are with #138 thread and a size 21 needle. However, I get just fine results with #69 thread and a size 18 needle. Quote
Moderator Wizcrafts Posted October 21, 2020 Moderator Report Posted October 21, 2020 1 minute ago, Rylando said: The above pictures are with #138 thread and a size 21 needle. That is the wrong size needle for #138 thread. You should use at least a #22, if not a #23 leather point needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Rylando Posted October 21, 2020 Author Members Report Posted October 21, 2020 8 minutes ago, Wizcrafts said: That is the wrong size needle for #138 thread. You should use at least a #22, if not a #23 leather point needle. Ah! Maybe that was my problem. Will go bigger needle and try again soon. I should know better than to trust the first result for me on google https://www.servicethread.com/blog/industrial-sewing-thread-needle-sizes Quote
Moderator Wizcrafts Posted October 22, 2020 Moderator Report Posted October 22, 2020 4 hours ago, Rylando said: Ah! Maybe that was my problem. Will go bigger needle and try again soon. I should know better than to trust the first result for me on google https://www.servicethread.com/blog/industrial-sewing-thread-needle-sizes Right! Try this chart instead: https://www.tolindsewmach.com/thread-chart.html I usually choose the largest recommended needle when I sew medium to hard temper leather. It needs wider diameter holes to overcome the friction. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
