Members EMI Posted November 12, 2020 Members Report Posted November 12, 2020 (edited) I am looking at a Pfaff 34 on sale for 100 euros (body only without motor/table). The sub class appears to be 34 -705/03-AL with roller presser and most probably wheel feed. The machine is advertised as leather working ( shoe uppers and medium weight leather ?) but except from parts list ( ref link below) I didn't manage to find any concrete info on the net or in this site regarding her stitch length, needle system and needle/ thread sizes. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.supsew.com/download/Pfaff/Pfaff%2034.pdf&ved=2ahUKEwiFub2vx_zsAhVH9aQKHdD3CasQFjABegQIAhAB&usg=AOvVaw2K_dytlfXdvb4zCPRLTaAu Furthermore the code letters AL are also a bit confusing to me (A= Light materials & L= leather). Does anyone has experience or info on this particular model ? Would you consider it as as a worthy purchase in a supplementary role to a Consew 226 for medium leather and synthetics/faux leather work ? I understand that spare parts may not be widely available ( if needed). Edited November 12, 2020 by EMI Quote
Members Constabulary Posted November 12, 2020 Members Report Posted November 12, 2020 (edited) Looks like machine has no reverse if that matters (short slot in scale plate) stitch length should be indicated on the stitch length scale (ask for a picture). Yeah looks like wheel feed. Expect a rather short stitch length cause on shoe upper you do not need a long stitch most of the time (maybe 2-3.5mm - check your own shoes) but it´s just a guess. Here is something about the 34 class (does not cover all sub classes!!!) maybe it helps a little bit. Pfaff 34 Info sheet.pdf Edited November 12, 2020 by Constabulary Quote
Members EMI Posted November 12, 2020 Author Members Report Posted November 12, 2020 5 minutes ago, Constabulary said: Looks like machine has no reverse if that matters (short slot in scale plate) stitch length should be indicated on the stitch length scale (ask for a picture). Yeah looks like wheel feed. Expect a rather short stitch length cause on shoe upper you do not need a long stitch most of the time (maybe 2-3.5mm - check your own shoes) but it´s just a guess. Here is something about the 34 class (does not cover all sub classes!!!) maybe it helps a little bit. Pfaff 34 Info sheet.pdf 369.29 kB · 1 download Thanks for the info. Lack of reverse is not such a big issue. However the "A" class designation (as opposed to BL ones I've seen in photos on the net) is what puzzles me. Quote
