On 12/21/2020 at 12:37 AM, Dogfisher said:
I realize the tooling will create noise. It's my bench the amplifies the noise. Suring up the bench and the rubber mat might work. Thanks for all the input.
I have an off-cut  piece of 2" marble approx 14 x 12" , with a piece of foam/rubber carpet under-lay approx 1/2 thick, folded over .
You could always check for any vibrations, or  screws etc . on the bench that may need to be tightened, if any ? just a thought .
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
