LomaeArts Report post Posted December 19, 2020 A local shop has a reconditioned PFAFF 1246 twin needle 9.6mm gauge sewing machine. Is it possible to use as a single needle? Quote Share this post Link to post Share on other sites
Constabulary Report post Posted December 19, 2020 (edited) yes you can but you cannot use single needle feet. The current setup has to stick with the mounted feet. Just remove 1 needle and if you have to save the and 2nd hook I´d remove the entire hook but leave the gears as is. I think you can convert it to a full single needle 1245 machine but that requires new parts and moving the hook saddle and gears but to be honest I haven´t done this yet but I think it´s possible. Edited December 19, 2020 by Constabulary Quote Share this post Link to post Share on other sites
