Hi all!
I have been reading, and reading and reading some more, and I have come to the conclusion that there is no one right answer on how to finish projects! I'm just looking for some reassurance that I am on the right track. I am making nosebands and small saddle bags to hold cell phones. I'm currently using Tan-Kote and Aussie conditioner. Is this enough protection? I know these are not heavy use type items, and aren't intended to be used out in the rain- but could still get wet. So is the Tan-Kote and Aussie enough protection? I'm always worried about water spotting/dye running.
I have used resolene in the past but I really dont like the shiny, plastic look. The dye I use is Feibings Pro dye, and also use Angelus acrylic paint.
  • 1 month later...
Don Gonzales uses a Tan-Kote finish on his saddles and tack.  It can be reapplied as needed.  I've noticed Tan-Kote lifts some of the pigment from leather I've dyed with Fiebing's leather dye, and discolors the stitching.  Do you see this happen with Pro dye?  I'm brushing on a light coat of neatsfoot oil after stitching , letting the oil soak in overnight, then applying Tan-Kote.
I do notice it does lift a bit of colour when applying. But I usually do my stitching after the finish so I haven't had any stitch discolouration happen.
