Hello,
I'm on the hunt for an affordable hand press to set buttons and snaps into my projects. I tried last night to set some with the little rods and anvil that came with my button kit and it was a nightmare. I ruined about 10 posts, caps, and sockets before I got one to take hold.
I found this one on Amazon, but it doesn't come with any dies. I can only find dies for 15mm buttons. I want to be able to use 10mm and 12.5mm buttons as well.
https://www.amazon.com/dp/B07VB2SXQS/?coliid=I2A921RJXL9IEF&colid=238SAUAALRARW&psc=1&ref_=lv_ov_lig_dp_it
Is there anything similar out there that doesn't cost $200?
LC
27 minutes ago, Loudcherokee said:
Hello,
LC
The Amazon price is too much. What size snaps are you setting, line 20, line 24?
The ones I ordered didn't have that designation. It was a multi-pack in 3 different sizes, but the post size is all the same.
Lc
Lc
Here is an ebay search that should help with what you are looking for.
https://www.ebay.com/sch/i.html?_from=R40&_nkw=hand+press&_sacat=0&rt=nc&LH_PrefLoc=1
Just past the juice presses is a set of 3 snap dies.
Thanks! I'll check those out. I looked at the line 20 and line 24 snaps. Those are different than what I'm using, which was a 655. They will require a different tool all together.
LC
LC
Another name for the snaps you using is Segma Snaps.
I just found this search, has everything you need and you will have enough money left for over for a coffee.
https://www.ebay.com/itm/Hand-Press-Machine-Snap-Button-Grommet-Rivets-Eyelets-Fastener-Dies-Mold-Set-DIY/124424546080?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20160908110712%26meid%3D0f8d709abb764719a70dfbb227467871%26pid%3D100677%26rk%3D3%26rkt%3D30%26mehot%3Dpp%26sd%3D392918784131%26itm%3D124424546080%26pmt%3D1%26noa%3D0%26pg%3D2386202%26algv%3DSimplAMLv5PairwiseWeb&_trksid=p2386202.c100677.m4598
Edited by ryano
Thanks! That one on ebay is listed out of stock but I found a similar kit and placed an order! Appreciate the assistance!
I will still need to either find some dies or get a good hand tool for the line 20/24 style button snaps though. I plan to use those on a few things.
LC
LC
I will look for some line 24 snap dies a little later today.
Do these look right? Is the line 20/24 snap considered an 831 in the Segma designation?
https://www.ebay.com/itm/4pcs-Set-10-12-15mm-Snap-Button-Dies-Mold-Fastener-Tool-For-Hand-Press-Machine/293818327385?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20190917065201%26meid%3D8446804e768f4ae4948f7e9a5b4fea75%26pid%3D100935%26rk%3D1%26rkt%3D12%26mehot%3Dco%26sd%3D152480114727%26itm%3D293818327385%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimplAMLv5PairwiseWebWithDarwoV3BBEV2b%26brand%3DUnbranded&_trksid=p2332490.c100935.m2460
ETA those are probably wrong. I think the 20/24 style is actually 201 not 831. This is all so confusing. Almost as bad as thread sizes!
LC
Edited by Loudcherokee
17 hours ago, Loudcherokee said:
Those dies look pretty odd to me, especially the one with the retaining spring. I saw where a metric conversion converted the outside 24 line snap as 15mm, but did not show conversions of the 2 interlocking pieces, so I would be afraid to try them. Also beware of plastic die listings, they will surely fail. Used dies get listed, on ebay, one in awhile under United Carr.
Here is a set of 24 line snap dies that look correct and is only 25% of the usual price of 100 bucks, as you can see look a little different than the ones you posted the link for.
https://www.ebay.com/itm/DIE-SET-FOR-HEAVY-DUTY-MIGHTY-SNAP-SIZE-24-5-8-FREE-SHIPPING-USA/264745077024?_trkparms=ispr%3D1&hash=item3da4094920:g:UGoAAOSwO9ZezpAq&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkXKoKcbeZcOrOku%2BoOBl%2BSxuMciqcoA0WrBomRi4LsqlaDIcA9UrZpXteVa%2FizpLLQVGAyGgtCq0MIjZG2M%2FHVhM5K1BMRvvrqaBHqeXdKK7vx5yRw%2By2zbJ2dze1m8ERco8CkyjdywrXZ23y%2FKFWFIPPsxzn%2FEB80PhQTTDT4DlA8ZWAXQcDRYJNkpZlZMY%2Bd%2FpdRuYJpL8NHrBKVTm%2FR5CFIS70Np6Ovu6qfkkJXLEt2sxJRvbYZhUARJLt2Rz1ZGe3kGjPUzGhtkuBt0U6lOBYteXnZLmzKmq6TmuZ5qJEkQMeW%2FtcBVzvZExeRSMMnEpzsEqUiMJb3gqp5PnJduMoYaHO7MrdSRYRftUS46Ig%2FVmydVbCrFRy%2BA8YBvmsruVTC967c16yHdhvkvHMRkg81hboAcmMAdeDx%2FHqQRNTxKbcB7tGP8wL%2F8l1HwpN5wa0Zvmmk%2BD12xFASnyeHPbNEAqmbd1ltwvjjBLRkt0BFt1DyLxrvmIautl0NjdQwvUXBxU9wl%2FrupPh5ZhI7cSJhaSsCPHy5cBHj4gUmaAC4VGTR9X1q58L4SQz13tGMwt1CvbwgZLrCzRyVUwiFsdAiEJdokkTg8oqnswBmYsk18toKb2v7%2BdS0DqGJzFDh3f5DSR9ehuxyStyYGEysMpYc3wKzOkRqbcvjlY222hXuXAsI9E60moevMPQeUKFLJOQ7hrnzxvfpx4wEmZMHiXVkrI6D5P974ev1rlQnsQYG5eMcEByfPrwEqpXB4aR%2B2jycdIGjkjO6p9j1Zu9yQ%3D%3D|cksum%3A264745077024581f3c6bb92c47c1a7c046fa6f069d7a|ampid%3APL_CLK|clp%3A2334524
Edited by ryano
"Line" (originally "ligne") refers to the cap diameter.  It's an old unit of measurement:  40 lignes = 1 inch.  Some modern button manufacturers use "#" instead of "L" but it's all the same:
https://www.workroombuttons.com/thumbnail.asp?file=assets/images/ButtonChart.png&maxx=300&maxy=0
  20L / 1/2" [12.5mm] and 24L / 5/8" [15mm] is a size common to ring spring snaps, sometimes called "industrial" or "durable".  The ring (a literal wire ring) is inside the cap and provides the gripping action for this type of snap.  Segma snaps have an entirely different gripping action.
  Setting machines are just specialized arbor presses.  As long as everything lines up and the machine is solid, you're in good shape.  Definitely consider the DIES, though.  Different machines accept different die shanks.  The two most common are M8/19mm and 3/8".  Most foreign die shanks are M8/19mm; most US die shanks are 3/8" —they are NOT interchangeable.  M8/19mm shank dies tend to be cheaper; 3/8" shanks can be more versatile (top and bottom dies can be switched around).
  At this point, you should be considering the types of snaps you plan to set, now and in the future.  Select a machine that accommodates the kinds of dies you need (or will need), and be very mindful of the shank size.
Edited by ButtonLady
Added some measurements.
Sewing Machines:  Juki DNU-1541 and waaay too many home machines and sergers...
Button Machines:  Osborne, Wade, Defiance, Maxant, Handy Jr. #1 and #20, Fasnap PM5 (and too many dies to count)
Wow! Thats alot of info! Thank you for taking the time to explain all that.
The press i ordered has M8 threads for the dies, so when looking for the button type snap dies ( like what would be used on a holster) I'll make sure to look for that thread size.
I had originally thought the line 24 just had a longer post than the line 20 due to Tandy website listing the 24 for 8/9 ounce leather and the 20 for 4/5 ounce. Good to know its an actual diameter measurement.
If I get rolling with this and can justify one of the nice Master Tools machines later on, I'll look into that but for now I'm ok using the cheaper stuff from Ebay and Amazon.
LC
I sent them a message asking what the thread size is on the dies, and if they will work with Pull the Dot snaps.
Thanks for finding that!
LC
The 24L post is actually longer (and wider) than 20L, but that's because it's proportionally larger all over.
Be aware that Master Tool shanks are 3/8" (and will not fit the M8/19mm machines you're looking at now).
One-way snaps require a specialized die that accommodate the socket tab.  These dies are not available with a M8/19mm shank, at least I've never heard of one —I'd be very, very surprised if a stock (non-custom) version exists!  If you're planning to use one-way snaps eventually, you might be better off investing in a 3/8" machine from the beginning... and a one-way snap die eventually.  I believe Fasnap and Scovill (DOT) are the only non-custom manufacturers of one-way snap dies for machines (possibly also Rome Fastener).  All three also make their own version of one-way snaps:
I don't know if brand-specific snaps can be set in in other manufacturers' dies.  My guess is "most likely" but I don't know for absolute certain.
BIASED OPINIONS AHEAD:
I own a Fasnap machine, and Scovill (DOT) also makes a machine —both are excellent.  Both use 3/8" shank dies.  Neither machine is cheap, but they will outlive you.  Another option is purchasing a less expensive 3/8" machine and saving up for dies you really want:
You're very welcome! :)
Fixed some formatting.
FYI... Here are three types of snaps commonly used in leatherwork:
Round Spring (Ring Spring, Industrial, Standard, Durable [24L], Baby [20L])
round spring snap attachment
Parallel Spring
Parallel Spring snap attachment
Segmented Spring (Segma)
segmented spring snap attachment
Parallel Spring
Thanks again for the info! The snaps i have currently are parallel spring i think.
The ebay seller got back to me and said they are unsure of the thread size on the dies. They appear to be similar to the other Chinese dies that I'm finding so maybe they will work with other round spring snaps.
I will check out those machines you posted. Thank you!
LC
ETA - that machine from very baby looks just like one on Amazon that uses 1/4" shank dies.
The craft tool looks nice, but ouch dies are $120 a set!
I *think* the Amazon example is a M6/12mm machine.  Assuming I'm correct, this is not a very common size and (assuming I'm correct) Gold Star dies are compatible:  https://www.goldstartool.com
You would be limiting yourself to a very limited range of die types and sizes if you purchased this machine.  However, if it is a Gold Star clone, you can buy a 3/8" adapter kit for... $95.00 (!)
On 1/8/2021 at 10:22 AM, ButtonLady said:
  20L / 1/2" [12.5mm] and 24L / 5/8" [15mm] is a size common to ring spring snaps, sometimes called "industrial" or "durable".  The ring (a literal wire ring) is inside the cap SOCKET and provides the gripping action for this type of snap.
Oops... missed the edit window.  Snap springs are in the SOCKET, not the cap.  I need a vacation...
