Zonker1972 Report post Posted January 22, 2021 I got a bit annoyed with how long it took me to get out my stitching pony. since i made it, i decided to modify it. it is now mounted under the bench. it slides forward on some 1/2" bolts and then mounts to the front of the bench using a 5/16" bolt and a threaded insert in the bench front. in the left side pic you can see that i also built a swivel base that i can mount on the bottom of this pony to turn it any angle that works. i saw a pony like this on etsy and decided to make one. i've got another pony that isn't so elaborate that will mount to the bench front just to the right of this pony (see the two holes for the threaded inserts. Now, i just need to start using the ponies for stitching up some motorcycle items. zonker Quote Share this post Link to post Share on other sites
