  • CFM
This how I cover a whip handle,
You need,  A a piece  of 3/4'' pvc what ever length you need
A 3/4pvc cap, for the other end, i use a 1'' coupling, a 3/4 coupling
You will need 25 lengths of lace  6'' longer than the pipe
1 piece of lace that will spiral around the entire length of the pipe
For the other end
saw the 3/4 coupling in half. inside the 1'' coupling is a small pipe stop ridge,  dermal that ridge gone
the 3/4 coupling should slide into the 1'' coupling
push it in half way glueed
cover the 1'' coupling with a braid
slide it onto the handle that you made,  the coupling should over hang the pipe just enough to dress up the edge
epoxy the whip into the 3/4 pipe
Edited by Frodo
  • 3 years later...
  • CFM
I found my 10 year old old bull whip and maybe this will shed some light on how to make a whip handle visually
This is a paracord whip , it laces up the same as leather
IMG_0358.jpeg.2e0dad4688b53aa837f747f27af8c4c2.jpegIMG_0360.jpeg.2c8cbbbe7bbbd2c5aad114c02d706a07.jpegIMG_0361.jpeg.0cb7b54acda48f6d4bd4c7799df30fe9.jpegIMG_0362.jpeg.f086fb6b2f259c2d148752cc4bc56ca4.jpeg
