Members Aven Posted February 18, 2021 Members Report Posted February 18, 2021 I've used a piece of elastic, the thin, white stuff. It isn't perfect, but when you are tired and don't want to do math, it works well enough. Using a cup as an example. Cut, or place a mark on the elastic (unstretched) that matches the circumference of the bottom piece. Lay out your stitch marks, like one every 1/4 of an inch. Then take that elastic and lay it on your stitch line for the side so that the end mark is next the beginning. The elastic will have stretched a bit to get around the cylinder and the distance between the stitch marks will be evenly spaced. Quote
CFM chuck123wapati Posted February 18, 2021 CFM Report Posted February 18, 2021 1 hour ago, Rahere said: Which is one heck of a distance between stitches! On the other hand, you don't want so many holes in the base it tears our. was just an example for the math. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Zozo Posted February 19, 2021 Author Members Report Posted February 19, 2021 1 hour ago, chuck123wapati said: was just an example for the math. Oh I know I understood what you were saying and thank you Quote ¡Te quiero! ; )
