Members sbrownn Posted March 15, 2021 Members Report Posted March 15, 2021 7 hours ago, chrisash said: Is there a general guide on how much you can reduce the thickness to avoid distorting the leather, for instance reducing 3mm leather to 1mm may be to much strain on it even with multiple passes, of do people just limit the reduction to say half or a quarter of the original thickness so you would reduce 3.. to 1.5mm or about 2mm Yes, I agree that is true. The problem I had though was no matter how many splits I was using, when I got down to the last few splits the leather was already so thin that it deformed when I was pulling it through the splitter. I found a used Landis hand crank splitter for $100 that just needed it's blade sharpened and it works so well I just never use the pull through splitter anymore. Quote
