Members MichelleHills Posted May 20, 2021 Members Report Posted May 20, 2021 Hello. I am starting with leather work for the first time. I have done plenty of other sewing before. But I am not sure which sewing machine to buy for making leather slippers. I have seen a couple of second-hand options in my area that are all similarly priced: Harrison OY335N Adler 69 Kingstar KS-355 E-sew ES335BL Are there any specific things I should look out for? Am I right in assuming I need to get a cylinder arm, walking foot? Any suggestions on which machine is the best option? Thanks. Quote
kgg Posted May 20, 2021 Report Posted May 20, 2021 1 hour ago, MichelleHills said: But I am not sure which sewing machine to buy for making leather slippers. I would first decide on what size of thread you need / plan on using. The 335 class machines usually are rated at V69 (Tkt 40) thread which is basically the top end thread size for domestic weight thread. I would advise a class 341 or 1341 class machine as they would give a broader thread range of up to V138 (Tkt 20) for top and in the bobbin. However others can advise on what type of machine like a post bed maybe best suited for your needs in making leather slippers. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted May 20, 2021 Moderator Report Posted May 20, 2021 Three of the four machines you posted pictures of have synchronized binder attachments. These machines are used to sew cloth binding over edges. Because of the way the binders feed the folded cloth, the machines are often set up without a 4 motion feed dog. If the machine you pick only has a sliding feed dog, it may interfere with sewing your sandals, especially if they are leather soled. In effect, the feed dog will be trying to push the work back towards you as you try to sew it. The only machine without a synchronized binder is the one called e-sew. If it has a 4 motion feed dog, it may be a better choice. A 4-way feed dog moves forward and backward and up and down. It is also known as "drop feed." Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members MichelleHills Posted May 21, 2021 Author Members Report Posted May 21, 2021 Great! Thank you very much for your advice! It is much appreciated. Quote
