Members bootswithjay Posted June 22, 2021 Members Report Posted June 22, 2021 I recently acquired a 52w22 post stitcher. I am struggling to really figure out how to get it all working. Every time I go to stitch, I end up with bunching on the bottom side of the leather or a knot near the bobbin. Does anyone have a resource that can help with threading and tensioning this particular machine or one similar? Quote
Members Constabulary Posted June 22, 2021 Members Report Posted June 22, 2021 Please post pictures of your threaded machine so maybe we can see if something is wrong. There are 2 types of 52w. THis manual is for the earlier type. Maybe it helps Singer 51w100 and 52w100 - instructions for using and adjusting.pdf Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted June 22, 2021 Moderator Report Posted June 22, 2021 Generally speaking, thread knots on the bottom means excessive bobbin tension, inadequate top tension, a needle that is too small, or the top thread is not fully seated in the top tension disks, or the disks are not fully closing as you sew. Pick one and run with it. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members bootswithjay Posted June 22, 2021 Author Members Report Posted June 22, 2021 3 minutes ago, Wizcrafts said: Generally speaking, thread knots on the bottom means excessive bobbin tension, inadequate top tension, a needle that is too small, or the top thread is not fully seated in the top tension disks, or the disks are not fully closing as you sew. Pick one and run with it. How does one adjust the bobbin tension? I've fiddled with the top tension, but I don't know how to mess with the bobbin. Quote
Members LindanHotAir Posted June 23, 2021 Members Report Posted June 23, 2021 On the side of the bobbin case there is a flat spring. There are 2 screws through the spring. One attaches the spring to the case, and the other screw adjusts the bobbin thread tension. Turning it slightly clockwise increases tension. Quote
