Members bootswithjay Posted June 28, 2021 Members Report Posted June 28, 2021 I am currently struggling with the 52w22 post stitch twin needle and have a couple of questions. 1) My top stitch is not locking with may bottom thread, resulting in the lack of a finished stitch. It will occasionally catch, but not always. Currently I am using a fairly cheap nylon thread. Could the thread be causing the issue? Is it a problem with tensioning? Or timing? 2) I need a second needle set screw. the gentleman who had it before me only used it as a single needle machine. Does anyone knew if other set screws from industrial machines could work? Thanks for your help. Quote
Members Constabulary Posted June 28, 2021 Members Report Posted June 28, 2021 (edited) Posting pictures will help to figure your problem. Needle clamp screw should be parts number 201030 and should be available from a sewing machine dealers. But better check the parts list of your machine. Check the needle hook timing when the hook is not catching the thread. Most likely needle bar is a tiny bit too high. Edited June 28, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
