rgerbitz Report post Posted September 12, 2021 Good afternoon People, What are some options for repairing this horn, that do not include removing the swell cover? Thank you, Quote Share this post Link to post Share on other sites
bruce johnson Report post Posted September 12, 2021 Few options Take some skirting scrap and build up the burned out are at the bottom of the neck to make it level. Wrap the neck and back lip of the horncap with a mulehide wrap and then put the rubber on over it. - easiest Strip off the horn leather and recover the horn. Leave the wings long and tack them into the gullet. Cover with a mulehide wrap and rubber over that. 2nd easiest. Quote Share this post Link to post Share on other sites
rgerbitz Report post Posted September 12, 2021 Thank you Bruce! Quote Share this post Link to post Share on other sites
kseidel Report post Posted September 14, 2021 Bruce is correct in his reply. However, this swell cover is not that hard to remove, and if the job warrants, it is easy enough to remove and recover the horn under the swell cover as original. Keith Quote Share this post Link to post Share on other sites
