18 minutes ago, toxo said:
Servo shaft diameter? Can't remember my details because I did a similar conversion on my Durkopp239 but they are out there. You can even buy pulleys that you can bore out yourself.
Try Googling 40mm/45mm sheave instead of pulley.
ah but yes if I was equipped with a lathe it would be a child's play.
Thx.
time does not respect what is done without it
https://tradisign.blogspot.com
https://www.instagram.com/tradisign/
Thx.
You don't have a hacksaw? chop the shoulder off, clean up with a file. If it has a shoulder it will usually have a set screw in the shoulder and not a keyway. After you take the shoulder off, drill and tap a diagonal set screw hole to hold onto the shaft. We're not dealing with massive torque here. If there's a shoulder on the shaft for the new pulley to sit on you might only need a serrated washer under the nut to hold it in place.
Edited by toxo
yes yes i can do it! thanks sir.
If you get stuck, there's a bearing shop not far from me and they're really helpful. Give me the relevant measurements and I'll call them tomorrow.
If you do a search on my content you should find the post I did on it.
Thank you very much, I just remembered that I have a brother in law who is a lathe-mill-fitter with whom I have an excellent relationship!...;)
  • 2 weeks later...
he made me the right product for my needs...
https://zupimages.net/up/21/42/k4sn.jpg
Edited by paloma
