Members OneShort Posted November 16, 2021 Members Report Posted November 16, 2021 I recently bought a Consew 206 RB-5. In taking off the front cover on the needle end of the machine I found a oil wick that is hanging above the thread and lower feed dogs. See oil wick included photo behind the seam ripper (you might have to scroll down some to see where it ends). Can someone else with the same machine verify this oil wick is where it is supposed to be? It seems like it would drip oil unto the material being sewn. I have found some pics from RB1 to RB4's but they don't have this wick in the pictures I've seen. If it is routed differently, can you include a picture of how it should be? Thanks much, Steve (aka one[wick]short in this case) Quote
Members Jhunter13 Posted April 10, 2022 Members Report Posted April 10, 2022 I know this is old, but did you ever get an answer? Im in the same situation. Quote
Members Constabulary Posted April 11, 2022 Members Report Posted April 11, 2022 usually the wick end is hanging into a small "pit" in the casting where access oil is collected which is behind the 3 bars. Not sure if it is the same on the 206 but maybe worth checking. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
