:helpsmilie: I have been using the Acrylic Resolene Finish and find that it is inconsistent in its application. At times it finishes fine on my holsters and other times it leaves water marks and uneven color tones and I can not figure out why this is happening. I apply the finish with a wool remenant in a consistant manner. Could the type of applicator that you use cause this inconsistency or is the Resolene just an inconsistant finish? I have attached a picture of the end of a game call holster that I make which shows the markings that the Resolene makes. You can see the streaks that it puts in the leather as well as at the end of the holster you can see the water marks that it made.
I am looking for a finish that provides a water resistant, durable finish for outdoor products but also provides a smooth and even professional look.
I was thinking of discontinuing the use of the Resolene and going with either the Leather Balm with atom wax or Super Sheen/Satin Sheen. Any suggestions?
Also, is it possble to use the Weaver's Tuff Kote in conjunction with either the Leather Balm with atom wax or Super Sheen/Satin Sheen?
Any and all help would be greatly appreciated. Thanks. ***Lisa
Lisa, . . . for several reasons, . . . I do not spray anything in by leatherwork. I daub or dunk my dyes, . . . and brush on my Resolene.
I cut the Resolene 50/50 with tap water, . . . shake it well, . . . and with a camel hair, one inch (cheapie) brush, . . . I begin brushing the object. At first it is kind of slopped on, . . . but then I keep brushing and it will kind of foam up, . . . and just keep brushing, . . . the bubbles will all break and you will be finally brushing a polished surface. Hang it up to dry, . . . a little (emphasis on LITTLE ) heat will help.
The double rig was done that way, . . . all three pieces probably took 45 minutes total.
May God bless,
Dwight
www.dwightsgunleather.com
