Frodo
DIY Foot or Hand servo control
DIY, Foot or Hand control for a servo
misc. 3/8'' all thread rod /nuts/washers.
You will also need a spring. the ruger sling swivel connects the rod to the servo arm.
This is a very easy build that anyone with common hand tools can make
You will need a drill with a 1/2'' drill bit   the rod needs to be loose and able to move as it pushes up
you need a 1/4'' bolt 1'' long with locking nylon nut to hold the riser clamps, they also need to be loose
I used the spring from the clamp most of us have to hold our leather, I call them chip clips
The rod can be bent 90 degrees.  just take your time.  place  1'' of the rod into a bench vice then pull the rod slowly 90 degrees
I covered my rod with a piece of copper pipe.  as i scrounge more pipe i will cover the remaining rods
Edited by Frodo
very cool !!!!
