TALLNDN
Everything posted by TALLNDN
  1. I recall a while ago reading a user question on this topic, and am just getting around to adding my two cents worth. Rivets using plain stems cut just "long" of the "clench washer", then peened round to assure a permanent "set" can be challenging. The length above the washer is critical, and MOST easily attained with a compound diagonal cutter (colloquially a "compound dike") Using a "compound diagonal cutter" for these little wonders has been the only time-after-time reliable means I've found of quickly and accurately getting the post clipped off at the correct place without negative effect on my/your carpel tunnel. Got my most recent pair form Walmart for about $9.50. Amazon's got a DeWalt version for about $17.00, Just trying to help. Sorry about the delay in posting.
  2. In several of the posts here I see folks using a little tool that looks like a very small spatula - or maybe a round-end trowell that has an abrasive surface with which the path intended for glue application or getting rid of surface issues prior to stitching. I hope to have described the use well enough to get a repl or two. Please?
  3. Even if this has been posted before, it probably ought to be posted again: I recently moved, but when my stuff arrived, my granite block had somehow "disappeared". So I went to a local granite / marble countertop shop, told the guy my problem, and he even helped me dig through his scrap pile. Wound up with a lovely 26" x 18" x 1 3/8" perfectly flat polished granite tooling surface ABSOLUTELY at no charge. The guy even helped me put it in the back of my truck. While there, I picked up a couple of smaller pieces for use in tight spaces and so forth. Even if you think your local shops might cooperate, it's worth a try to find out - no?
  4. For general consumption https://www.nkunaturals.com/blogs/nkus-skincare-blog compares Shea butter and Cocoa butter. Although the discussion there has no focus on leather, Cocoa butter attributes seem best for working leather (cowpoke stuff and backpacks) while Shea butter might tip the scale for more delicate items. It's a "U=PIKem", but informative and interesting.
  5. Thanx. Being a Western Oklahoma Geek, I'll always try to reduce things to the simplest level (science?) . There's a LOT of viscosity data available online, all of which show seed oils roughly the same at room temperature. Canola is thickest, EVO is "mid range". Then there's a gap after which Almond, Peanut and Walnut are very close to Pecan Oil - the least. Roughly the same relationships hold regarding "substance internal molecular friction" (again - roughly - lubricity). As it heads toward becoming cold, Canola again leads the pack, becoming "sticky" rather rapidly. My thought is: All of this backs your formula as elegant. Leather is a relatively dense collection of fibers rubbing together when moved. I think that as whatever seed oil is used reduces viscosity and internal friction of lubricants (cocoa butter, lanolin) as they "penetrate" (get into and between fibers) resulting in it beng more supple, and therefore - "conditioned". Then as the seed oils degrade or evaporate, additional "conditioning" is needed. Furthermore, almost all of the MSDS sheets I can find of the common "conditioners" show significant (almost shocking) amounts of petroleum products in their formulae. Petroleum products (mineral oil, paraffin, petroleum distillate etc.) will chase moisture and natural oils from whatever they encounter. That will wick lubricants OUT of the leather, making it eventually crack, rot or degrade in some fashion.
  6. Thanks a heap. I notice in the recipe you include "(or similar non greasy scented oil)" Going to have to try the almond oil along in an experiment (fooling around) I've got going. Couple of days ago I ran out of Extra Virgin Olive Oil (EVO). Just for the heck of it, I smeared some cooking-grade peanut oil onto a scrap of 6oz veg tanned leather. In making stir fry, I've often observed the very low viscosity of peanut oil, so the speed with which it INSTANTLY penetrated clear through the scrap shouldn't have surprised me. But it did. It was as though the 6oz veg tan wasn't much more than a filter. So - tried Canola Oil to virtually no effect. Got more EVO. Relaxed the veg tan some not great but some. But the peanut oil caused the 6oz veg tan to become relaxed that same sample to just plain FLOPPY. I also use Walnut oil for shellac finishing fine wood pieces - going to try that also and document results in a week or so. What I really want to know is: has anyone else on this site tried alternate seed oils, and if so - to what effect in finishing, especially with Tan Kote. anyone?
