Trucker
Everything posted by Trucker
  1. On people not smoking.... maybe 1/3 of the people I've made pouches for in the last few years have now given up! Running joke is if you want to stop smoking buy a pouch off me
  2. Done this only a few dozen times so far. Mark the bottom centre on all parts. I measure the curves on the stitch line with soft bendy ruler or tape from that centre each way, then cut a bit long. Then test fit it with clips and mark it. Then glue liner on if im using . Then test fit it again, just to be sure, then I'll fold and stitch or whatever the tops of the gusset. I'll finally glue it and stitch. Been caught a few times where the front and back panels join up slightly uneven with the gusset. Only takes to be a couple mm off the stitch line to change where it ends up. Gets way easier once you get one right and make a template
  3. Been making baccy pouches for years. Mostly just keep them simple but put a bit extra in occasionally.
  4. So, I've cleaned and oiled the shuttle, measured hook timing, needle height and feed dog height, etc, all to specs. Everything is wicking oil (a little too much down the needle) and it's still well greased. It sews just fine. Except.... Presser foot won't lift till it's set at about 3 or so, needs to be at about 6 to actually lift enough to move the leather. And stitch length needs to be above 3 or so to even separate the holes. Set on 8 makes a 4.5mm length. Was almost exact to the setting till the clutch tripped. So something has moved. No evidence of teeth broken and no metal bits floating around, and everything is tight. Been studying all the linkages and movements, and the books and diagrams, but still not confident enough to start loosening screws until I know exactly what moved? And why? So can anyone help? Maybe a photo pointing out what to adjust?
  5. Thanks for that! That's the detail I need to understand the mechanics and settings of how these things work.
  6. I've just purchased the Cowboy 6900, (4800?) the first electric machine ive ever used. Been quite the learning curve! Mainly teaching my left foot... Had an Outlaw for several years but found its limits with bag making and thinner leathers. I have made 3 or 4 bags quite successfully and am loving it so far. So much easier and more accurate with 2 hands holding the work Problem is I had a jam that tripped the clutch. Mistake learned! Reset it but now the stitch length is way too short for the dial numbers and it's not walking the material thru properly. Looks like the dog is sitting too high and maybe not timed right, seems to grab the material and pull it back to the front. It stitches okay so hook timing is good, but a 6 on the dial is only about 2 or 3mm on the leather now. Something has shifted. Watched and read everything I can, but not sure what, where and how to adjust to make it right. Help please?
