leather monger
Everything posted by leather monger
  1. thanks wiz didnt think it would be that hard fo tind a part to it knew i should of come here firs lol i do thank you very very much
  2. im having a hard time finding parts for my singer 29 k 7s i have a needle bar thats cracked at the top and is fraying my thread an breaking it anyone know here i might find this part and any idea how much one would cost me PLEASE I NEED HELP LOL
  3. anyone have a pattern for a bandoleer holster that i can run to staples and have run off not a doc holiday rig i have a patter for that but i need the pattern for the bandoleer itself
  4. its called a saddlers needle gives you a better grip on the needle when your goin through heavy leather like saddle skirts or saddle leather
  5. we just used a cheap clamp on fixture from the home depot and put a heat lamp bulb in it and we set it in a metal box so the bulb would be about 10 inches from the sole and just turn it on and keep an eye on it till it just barely starts to smoke a little youll have a big mess if you forget about it the rubber will melt
  6. we use a heat lamp not a heat gun sorry not to mention that we get it till the rubber is just starting to smoke we do wth whole sole under the lamp then we take it out and start peeling it back then use acetone in a solvent type bottle with spout on it and as we pull the sole back we squirt a acetone on it to disolve the glue we use a heat lamp not a heat gun sorry not to mention that we get it till the rubber is just starting to smoke we do wth whole sole under the lamp then we take it out and start peeling it back then use acetone in a solvent type bottle with spout on it and as we pull the sole back we squirt a acetone on it to disolve the glue
  7. i work at a shoe repair shop and we use a combo of heat then take it out of the heat and then use acetone to dissolve the glue it works good but must make sure it doesnt change the color of the leather
  8. please add me to the adult section
  9. thanks twin the micro bungee seems a great idea ill try that one be able to start the stitch wihout holding the threads
  10. thanks gringo that helps me alot i also have an old singer 31-15 and a 29k72 singer on a treadle base so i hope im covered with everhing i need now lol
  11. from the owners of the tippman boss what is your honest opinon on the boss i just ordered one for making holsters and belts i know its got its quirks but every machine does
  12. im gettin confused on needle sizes need to know the correct size needle for my singer 29 k 72 im gettin different sizes in different numbers lol HELP PLEASE
  13. i have a singer 29k72 machine with the hand wheel on the end what would be needed to switch it to the front and does anyone sell or have parts to do that with
