Hello folks,
Long time lurker, first time posting. I'd like to ask you about the method you use to dye your leather.
I have tried a few techniques with varied success. I started using wool daubers to apply water and oil based dyes, and found that it applied unevenly; if one stroke overlapped another stroke, that section would be darker than the others. It was very hard to achieve a consistant, even look. Even when using dye prep I got the same results.
So I decided to try submerging the leather in dye. This was easy to do with small projects like bracelets, though it uses a lot of dye really fast. I liked this technique because the edges and bottom of the project would all be dyed the same colour. Though it takes 2 days to completely dry.
What techniques do you folks use? I could use some advice before I run out of dye.
Can you water dyes down? Water down oil based dyes?
Thanks to everyone who replies.
