knazim
Content Count
63 -
Posts posted by knazim
I have my own laser engraver and have used it extensively on leather. I first dye, apply finish and then engrave. See my pictures below of my work:
https://www.etsy.com/listing/159793131/ipad-nexus-kindle-galaxy-tablet-leather?ref=shop_home_feat_1
Just make sure that your friend understands that when you laser engrave leather it really stinks and you need to ventilate properly. The smell permeates everywhere so keep a few cans of Febreeze handy
Regards
Khalid
For leather you should try:
Perfect Leather (on King Street, West of Spadina http://www.perfectleathergoods.com/index.html)
Fauk Leather ( Scarborough - Vic Park and Steeles http://faukleather.com/)
Moore-Pearsall Tannery Warehouse (100 Wingold Ave Toronto, ON M6B 4K7 mptw.ca +1 416-789-3123)
For tools and some leather, try
Capital Findings and Leather (215-160 Tycos Dr, North York, ON M6B 1W8, Canada Phone:+1 416-784-5888)
Leather and Sewing Supply Depot (7 Vanauley St Toronto, ON M5T 2V9 - Phone:+1 416 9134868)
Regards
KN
Wow! Where did you get these from? The package has China post marking on them. So probably not from Mando.
This is a Shenhui 80W CO2 laser. Bed size is 900mm x 600m. This laser has allowed me pursue so many ideas as I could cut and engrave nearly any material (except metals - which can be engraved by this machine if I spray a specific chemical on it).
You can check some of the things that I have made here http://www.flickr.com/photos/kustomkalligraphy/.
Regards
KN
Hello everyone,
I made a short video to show how I use my laser to engrave and cut leather. You can view it here http://youtu.be/VLSaYWZG2n0.
Regards
KN
Got it. Thanks for posting this and for the explanation. Time to try this now
Regards
KN
Have you tried bending/folding the leather to see if the ink is holding up?
Not really sure anyone will have the time to give advice, but figured I'de ask.
I have been doing gun shows for the last 3 or so months and came to a sad realization.
I cannot make replacement inventory as fast I am selling it no matter how many hours a day I work.
As an example, I have been making 20 to 25 a week and I am still behind.
I could raise my prices, but in my mind that would be a huge step backward as I would rather increase production.
Everything I have done to increase my production has worked well. Such as a 12 ton press, oscillating belt sander, drum dyed leather, convection oven and such. But I find my biggest eater of production time is in the cutting out leather using patterns and edge work.
I am considering using clicker dies instead of hand cutting but feel the need to be able to make the die myself and eventually have one for every holster in my line up. Is this a stupid idea? I can get the flat metal bender and make room in the shop for it but cannot find the pre-sharpened steel ruler stock on line or locally.
I now use a pro edge dressing for my holsters, unless a customer requests otherwise, but applying it with a q-tip is time consuming and wasteful at best.
In a nutshell I guess I am asking if there is anyone here with a small, one man, production shop that has the time to correspond with me about the process and items I would need to do this.
I have currently had to shut down to custom orders to catch up with regular line and gun show sales so any help would be appreciated.
Thanks,
George
I can suggest a crazy solution: Buy a laser cutter! I use it everday and its fantastic tool to have.
KN
@biglew: How did your experiment of cutting Chromexcel go?
This is fantastic. really good design and construction. Thank you very much for posting the pictures of the process.
Can you post some more pictures of the arrangement inside the bag. Also, what leather type/size have you used. Finally, you mentioned that the leather is tan in color but the photographs make the leather color look yellow. You may want to tweek the pictures to get the right color.
Regards
KN
Check this out:
Regards
KN
@Nuttish: Care to share your settings? I usually cut at 60% power and 60mm/sec speed. ( I have an 80W machine)
You are right about Chromexcel being hard to cut with laser. Any leather which has oils becomes very difficult to cut cleanly. Veg tan is easiest to cut. Chromexcel will require multiple cut passes with mid level power setting which might make it impractical to be laser cut.
My laser is from a Chinese company called Shenhui. Its an 80W machine with bed size of 900mm (36in) x 600mm(24in). Western made machines like Epilog/Trotec/ULS are very expensive and were out of reach for me. However, I am told that they are easier to use and more reliable. The Chinese machine I have is much less costly and I did not find them difficult to use or unreliable. Furthermore the customer service from the manufacturer in China is phenomenal.
If you are interested in lasers you should check out this laser forum (http://www.sawmillcreek.org/forumdisplay.php?8-Engravers-Forum).
Regards
KN
I would like to take this opportunity to thank each and everyone of you on this forum for the great help, support, advice that you have provided me to learn leather craft, answer questions, provide solutions to problems/issues and above all inspire with amazing work.
I feel very fortunate to be a part of this group.
Merry Christmas, Happy Holidays, Happy New Year to all of you and your families.
Regards
Khalid
I cut leather on my laser everyday and to remove the smell I use Fabreze Air Freshner - in the shop and also on the leather.
Where are you buying the microfiber from? I am considering making a case for my Note 3.
Regards
KN
Try doing a dip dye forv your belt black. Maybe that would give you better results.
I would disagree with Tina on this one. EcoFlo Professional Dyes are not like acrylic paints and don't just sit on the surface of the leather. You are probably confusing them with Tandy's regular ECO FLO dyes.
I use Eco Flo Professional Dyes everyday on products that I make and I have not encountered the issue that OP listed in her message. You need to put your dye in several layers with a dauber or sponge.
Regards
KN
Hi Paul,
This is fantastic. Great design and perfect execution. Truly inspirational. Keep posting... please!
Regards
KN
Fantastic work. Wow!
thanks for your suggestions. I have to try this now.
What is the best thickness of leather to use for a messenger bag?
Regards
KN
This is breathtaking ! I love this. Bowing down to you Sir Hunio
Question About Laser Engraving.
in How Do I Do That?
Posted · Report reply
@Nuttish,
I have 80W Shenhui Laser that I imported from China. My Chinese laser has been fantastic. The machine works superbly, never broke down in the last 3 years and the support has always been fantastic. So based on the my experience, I will not agree with you that chinese lasers the not worth it. They are absolutely worth every penny and allow people to get fully functional laser for fraction of the cost of the Western Laser machines.
@Dan 28
I would suggest to not buy the machine on Ebay but buy from the chinese manufacturers directly. These is extensive coverage ont this topic at Sawmill Creek online forum. Please check that before you decide to buy a laser.
Regards
KN
