So I've consulted the manual for this machine. It says the timing should be adjusted as such. After the needle bar has traveled all the way down. Raise it 3/16" or to the indicator mark on the needle bar (there is no mark on my machine) then the bobbin hook should be centered on the eyelet of the needle 1/16" above.  This is how the Left needle and bobbin are spaced and it works fine about 95% of the time. I've attempted to match the same timing and have got them in dam near identical yet they still don't work. I've pushed the right bobbin so close to the needle that in the full down position it's resting against the side of the lower portion of the bobbin. Any further away It won't grab the thread. Any closer and the bobbin case just pushes the needles over and farther away from the hook.
Another note I might point out is the right bobbin is a little more worn than the other, the hook is dulled slightly, I don't know if thats a critical issue. I would assume no since It worked fine in the 1/8" setting.
