Harry Marinakis
Everything posted by Harry Marinakis
Sorry, I don't get it. Can you please elaborate?
I am looking for advice on how to make a rolled edge with hidden stitches. By rolled edge I mean as if a the edge had piping, or like the leather was rolled around a 2mm cord. Other threads here that mention "rolled edges" are actually referring to folded edges, not rolled edges. Like this thread: http://leatherworker.net/forum/index.php?showtopic=57474&hl=%2Brolled+%2Bedge#entry369354 Any ideas on how to make rolled edges with hidden stitches?
Greetings I am looking for a pricking wheel to evenly mark stitching holes - not to actually pierce the holes. I am looking for a wheel that marks a hole every 1/4" inch, which I am unable to find. I am considering buying a pricker that marks every 1/8-inch and cutting off every other tooth. Would be nice to find something with an interchangable wheel, that includes 4, 5 and 6 holes per inch. A lot of the manufacturers offer overstitch wheels - but they are labelled such as "No.4" or "Size 6" which gives you no idea of how many holes per inch the wheel will mark (and no mention in the product description either). The Tandy overstitch wheel has 5-1/2, 6-1/2, 7-1/2 and 8-1/2 holes per inch (I measured them).
How To Get A High Gloss Smooth Finish
Harry Marinakis replied to asbandr's topic in How Do I Do That?
Fizan, the link doesn't work for me -
Sometimes it is useful to not dye both sides of the leather. When I make shoulder straps, often I will not dye the side of the strap that will be against clothing, to minimize the chance of staining (especially if there is chance of the leather getting wet).
I use a smooth bone tool and polish the leather to get a high-gloss sheen. I burnish after dyeing, just when it is almost dry. You want the leather to be very slightly moist so that it can be molded, so you can rub out all of the rubbing marks. The end results is a very smooth, glossy piece of leather. Then I apply a small amount of Renaissance Wax and it buffs out to a super high gloss. The image below shows the start of the burnishing process. The other image shows a burnished leather cover for a sword scabbard that was in the making. -
Raw, Veg Tanned Guitar Strap Question
Harry Marinakis replied to geckostraps's topic in How Do I Do That?
http://leatherworker.net/forum/index.php?showtopic=52975&hl= -
I have found that hardening leather makes it almost impossible to dye the leather. I used the baking technique to harden leather (soak leather in water, then bake on a form at 180 degrees F until dry)
What is the best way to remove sweat/salt stains from leather? I have a black oil-tanned leather jacket that frequently gets soaked with sweat, which leaves white stains. The leather is oil-tanned, and I keep it rubbed down with leather conditioners and waxes, and I even spray it down with an acrylic sealer. So it should not absorb sweat -- but it does. Neither saddle soap nor plain soap and water do the job. Here's what I've found using a search: http://leatherworker.net/forum/index.php?showtopic=53213&hl=salt http://leatherworker.net/forum/index.php?showtopic=46136&hl=salt#entry292663
How Do You Finish Natural (Undyed) Veg Tan Leather?
Harry Marinakis replied to Harry Marinakis's topic in How Do I Do That?
Here's what I've got so far. I wetted the undyed leather, burnished it with with a bone tool, and then as it was drying I polished the edges of the belt. Then I soaked the belt in Resolene and buffed it when it dried. it came out kinda marbled, which I did not expect from my tests, but I like it anyway. I've got to finish sewing the scabbard cover around the wood core, and then I'll lace the straps into the cover. -
Thanks So I've already got all the bases covered. Now I've got to try several tests and see if I like the results. -
I am making a piece and discovered that I really like the complimentary contrast of undyed veg tan leather and leather that is dyed dark brown. My question is: How do you finish and protect undyed veg tan leather? I would like to soften the leather and keep the undyed leather from getting soiled, from darkening from finishes that I apply, and would like the undyed leather to be water resistant. I plan to test a variety of treatments and finishes on identical pieces of leather, but I thought I'd see if anyone else has any other ideas. I plan io try softening with olive oil, burnishing with a bone burnishing tool, and applying Resolene and Renaissance Wax. Any other ideas?
The answer is probably, "No," but I'll ask anyway. Is there any way to prevent dyed veg tan leather from darkening when I apply Renaissance wax? Maybe a sealing agent? I've heard the Resolene won't darken leather but in my experience it does. Thanks
