Harry Marinakis
Everything posted by Harry Marinakis
I used the plan by Randy Steffan, found here: https://leatherworker.net/forum/topic/20586-stitching-horse-plans/ I modified the plan, and made the jaw vertical instead of angled. I really don't do a lot of punching holes by hand in heavy leather, so the ergonomics of angled jaws was unnecessary. Otherwise, the dimensions are the same as in Steffan's plan. Oh, I forgot, I made the jaws 2 inches taller than what's specified in the plan. I made the jaws by laminating strips, since I don't have a bandsaw large enough for this job. First I cut the Maple into four strips, each 21 inches long and 1-1/2 inches square. For each strip, I cut out of the shape of the jaws using a jigsaw. Then when I glued all the strips together I had the basic shape of the jaws. It took only a bit of work on the 4x36 belt sander for smooth out the final shape. I repeated the process for the shorter jaw. If I had to do it over again, I would make a few changes: 1. The plan assumes that jaws are angled left, so the mortise in the seat is shifted right. Since I made the jaws vertical, I should have centered the mortise in the seat. 2. There is a slot in the seat through which the leather strap passes. That slot is so close to the mortise for the jaws that the wedge has to be very short. I should have moved that slot in the seat for the leather strap further away from the mortise for the jaws. Then I could have made a longer wedge, and the jaws would be more stable. All the wood was cut from rough-cut slabs. The Cherry slab was 10 feet long. The Maple slabs were 6 feet long. Cherry seat with Maple trim on the legs. Maple jaws Maple lever bars 3/16" plate steel 1/8" plate steel Chair spring to pop the jaws open Leather strap Wood screws Tried & True wood finish
Period correct AND gorgeous
I made another tooling maul with parquetry. This time I recessed the bolts. The pommel swell is essential for a good, loose grip. I wanted this one to be smaller and lighter for more precision work, so I used lighter woods. Pine Giant Sequoia Madrone Camphor Plum 10 oz. UHMW head (2.5" tall x 3" diameter) 14.5 oz. overall weight. The larger maul has a 16 oz. UHMW head (3.5" tall x 3" diameter) and weighs 23 oz. overall. If you could have only one maul, then I think a perfect one-maul-does-it-all would have a 12 oz. UHMW head (3" in diameter).
GOOD IDEA!
I turned my wood mauls with a flat top. But I just knock them over all the time, so I don't stand them up.
There's a story behind the reason that an acorn nut is not there. I'd tell you, but I don't want to embarrass myself.
Cheap 4x36 belt sander. They don't last long, plan on replacing it every 5 years.
- 30 replies
- flesh side
- burnishing
(and 1 more)
I am looking for a leather with very special characteristics. - Soft as chamois -Anywhere from 5 to 9 oz. thickness -Doesn't stretch -Light cream or natural light color I was able to obtain this leather from Promise Land Tannery, but it's not available anymore. They advertised it as Latigo. Does anyone know where I can get such a leather? Many of us are looking for it, but we can't find it.
Skiving without a skiving knife? And Splitting with minimal tools?
Harry Marinakis replied to JC2019's topic in Leather Tools
Belt sander -
How to set pearls and jewels into leather?
Harry Marinakis replied to Harry Marinakis's topic in How Do I Do That?
Thank you Hilldale I searched on bezel but found only blanks, earrings, or pendants. Nothing that would even remotely suitable for leather. I guess I'll have to solder my own settings. -
Thanks but that suggestion was not useful. Anyone else have any ideas? -
I want to set half pearls and other costume jewelry into leather. I assume that there is a setting for half pearls and other similar jewels that have a rivet stud. But I don't even know what they're called. I've tried searching on Google, but can't find the correct search term. Can someone help? Thanks.
Soak those babies in Evapo-Rust to clean them up.
The usual procedure is to drill a hole in your anvil the same shape and size as the rivet head. Then place the head of the rivet into the hole and peen as usual.
Absolutely nothing in any of those photos is historically accurate. Questions: How do I get the shape molded for the pectorals? I've read about wet-forming but what would use/make as a mould? You could make a foam mold, or emboss the leather The chest seems to have a split down though the center to the bottom of the pectorals, I assume this is to be able to get in and out of the armor? You're reading too much into what you see. The armor is fantasy. What you see has nothing to do with purpose or function, it's all fantasy. The design, layout, methods of attachment, etc., are all fantasy, and are not similar in any way to any type of historical armor. Do I need to put metal eyelets in at the shoulders for the lacing? Not necessary, since the suspended weight is minimal and you won't be fighting. Just be sure that you set the eyelets in the leather far enough away from the edge that they don't rip through. The sides come together and attach with clasps under the arms, It looks like it's a perfect fit but should I make it slightly overlap instead? Yes, that makes it easier to adjust and fit properly The neck has a collar that comes up, how do I make it so it attaches all around? How do I attach it? Historically the neck protection was a separate piece (in most cases), worn under the chest piece, not a collar. Again, since this is fantasy you can make it and attach it in whatever manner you want. Question: For the edges which hold down the chainmail, do I cut one set of the side pieces short so that they don't overlap? or do I overlap them? Don't understand your question
I have made about 60 to 70 natural leather dyes, and here is some detailed information on what I have learned. 1. The best mordant for dyeing leather with a vegetable dye is potassium alum. Don't use too much, 5 grams dissolved in 100 ml of water is adequate. Apply only one or two coats of this mordant solution, and then allow to dry before dyeing. (The following vegetable dyes do not require a mordant: indigo, lac, walnut, woad.) 2. The following vegetable substrates are proven leather dyes, but generally they are not wash-fast or sun-fast: Brazilwood (pernambuco) (red and purple) Buckthorn berries (green, lavender, purple) Indigo (blue) Lac insects (red) Poke berries (red and purple) Turmeric root (yellow) Walnut (brown) Woad (blue) 2. You can either soak the leather in the dye, or paint the dye onto the leather. Indigo - very powerful, so dilute and brush onto leather sparingly Walnut - soak the leather for a day or two Every other dye - soak the leather for 1 to 3 days, or brush 5 to 10 coats of dye onto leather. Allow each coat to dry before applying another coat of dye. 3. To prepare a vegetable dye usually requires the following process: (a) crush the vegetable substrate and soak for one to seven days in either water, vinegar, or potassium carbonate solution (depending on the color that you desire); (b) boil and simmer for an hour, or two, or three, and then soak for a few days to fully extract the colorant; (c) strain the dye to remove the vegetable dregs; (d) brush the liquid dye onto the leather. 4. In general, you want to concentrate the final vegetable dye by simmering. A good goal is a final dye volume of 1 milliliter for every gram of dry vegetable substrate with which you started. In other words, if you start with 400 grams of dry brazilwood shavings to make a dye, then add as much water as you need to boil the shavings, but simmer the final dye bath until it is down to about 400 ml. 5. Adding crushed gum Arabic powder to the dye thickens it and gives the dye a nice texture. 6. There are a few natural non-vegetable dyes that are excellent. Iron-tannin-acid reactions produce wonderful grey and black dyes that are wash-fast, sun-fast, and rub-fast. A mordant is not required. 7. You can make an iron-tannin-acid dye by dissolving steel wool in household vinegar for 1 to 2 months (with the cap off). aka "vinagroon." Soak the leather in the vinagroon overnight, then rinse well. 8. To get grey, you'll need to boil 1 part ferrous sulfate with 1 part copper sulfate in a vinegar and tannin dye bath. Boil and simmer for a few hours. Allow to cool and settle, then decant the liquid and discard the dregs on the bottom. Apply only one light coat of liquid dye. The color takes about 3 hours to fully develop, so be patient before applying any more dye. 9. Making and using natural leather dyes is a bit of an art, so don't be too disappointed with your first results. Practice, experiment, practice, experiment.
