BruceH
Everything posted by BruceH
  1. Ron, How difficult is it to install the speed reducer for the Techsew 2700? Thanks, Bruce
  2. Update on Techsew 2700 Pro swing arm edge guide Apparently, the roller cannot be modified to be in line with the needle. I really wanted a different configuration. So, I figured out a solution that puts the roller guide exactly in line with the needle. Basically, I installed the bracket backwards. These are the following steps: 1. Remove the bracket (2 bolts) that holds the guide, Rotate the bracket 180 degrees. 2. Add spacers (4 washers totaling 3/4 inch thick) to each bolt hole. 3. Replace the bolts with 3/4 in. length and bolt on the bracket. 4. Slide back on the swing arm. What's nice is the set screws to stop the swing arm from sliding are now facing the front. Get a long allen wrench to easily reach the set screws. Everything else is working as advertised. And, with a great support team behind their products, I am a very satisfied customer. Thanks, Bruce
  3. Hello Babbs, I might not be the best judge of sewing machines because this is my first one. I had problems getting started but it was All User Error. Techsew has been very responsive to all my questions and problems with both emails and phone calls. Good support is key for me, especially since I am a "rookie". Now, the sewing machine is sewing great into 2 pieces of 4oz. leather. I expect that I will be very happy with this machine. I like the lase guide. it helps me keep the leather sewing in a straight line. I need all the help I can get. I am still waiting for the flatbed accessory, It is on back order. So, I cannot comment on that. I am very glad this accessory is included in the Pro version. The only issue I have left is with the swing arm edge guide. In the down position, it falls about 3/4 in. to 1 in. short of being inline with the needle. So, at the start of sewing I cannot bump up against the guide until I sew through 3/4 in. of leather. I should find out tomorrow what the problem is (probably me again). I will let you know what I find out. If you have any questions, feel free to ask! Sorry I couldn't be more help. Bruce
  4. Yes the "Pro" model has a few extra attachments: SmartServo-NP Needle Position Motor TLG Laser Guide Swing Down Roller Guide Flatbed Table Attachment. Since 2005, my passion was motorcycles. I hung up the two wheels and now I am hooked on leather craft. I usually "jump in" with both feet and don't look back. So, I have lots of learning and practice ahead. Thanks to you and everyone else, I am off to a good start. Bruce
  5. Thank You - Thank You I took the plunge and ordered a TechSew 2700 Pro. Because everyone's help, I believe that I made the right choice, finally. A special thanks to Wiz. Bruce
  6. Thanks for everyone's advice. I had strongly considered a flat bed and almost pulled the trigger. Then, I thought that the cylinder arm --with a flat bed attachment-- might be a more versatile machine, seeing that I am not quite sure where this is all leading. I tend to drive myself "nuts" with these decisions. My reasoning is that If I spend a bit more money now on the cylinder arm, I was hoping to lessen the chances of needing another machine in the near future. Wiz helped me see that I was overshooting in my range and that a light to medium weight (like the CB227r) is a better fit for me. I do not see myself doing really heavy leather work. That is when I narrowed it down to the TechSew 2700 and the CB227R. Am I correct that the cylinder arm with the flatbed gives me the most versatility? Do I loose anything by not buying a flat-bed only machine? I'm almost there hope. Thanks Again For Your MUCH Appreciated Guidance! Bruce
  7. Thanks so Much. This is such a great site for Info. You helped me determine that the CB3200 is the wrong machine for me, at this time. I will choose between the CB227R and the TechSew 2700. I know these questions are asked time and time again but I am open to any comments about either model. A great thanks to anyone that can help. Bruce
  8. Hi Wiz, I am new at this so I am not sure if this is a silly question: When you say that the CB3200 can sew from about 6 ounces, up to 1/2 inch. Am I to assume that thinner leather like 3/4oz will not sew correctly or sew poorly? I am looking for a machine with a wide range of options (wallets, belts. etc.) and leave my options open to 1/2 inch max. I can only afford 1 cylinder head machine. and was considering the CB3200. Thanks, Bruce
  9. Hello Everyone, I don't know quite how I got here. It all started (not too long ago) I couldn't find a rosary case that I liked. So, I decided to make my own. I went to Tandy, got some supplies and created my case. I really, really enjoyed the project. Add the speed light, my house began filling up with leather tools and supplies. Next is a sewing machine. Help, I don't seem to be able to stop myself. I'm hooked I'm looking forward to being a part of this community. What a great craft. Thanks, Bruce
  10. For me, when I see something is handmade, I have visions of someone doting over their work and making sure everything is just so. Finally, a high-quality product (the won't fall apart) is produced just for me. That's a nice feeling. Too bad that is not always true. On the other hand, when I hear of something being machine made, I have visions of something being forced though the production process at the cheapest and highest speed possible. On top of that, "inspector 1" had a hard night and was asleep at the wheel when my crummy product was missed in the quality inspection process. Arriving at my door is some piece of junk that I have to return. The real truth is probably somewhere in the middle of these 2 scenarios. Bruce
