Mark Peters
Contributing Member
Everything posted by Mark Peters
  1. Thank you. That is certainly something to consider going forward.
  2. Access please. Thank you.
  3. My second attempt at wet forming. I think I learned a bit working through this, but its clear that there is much more yet to learn.
  4. Thank you. When you cut down the post do you use something to then flare the end?
  5. I've carried a swiss-tech combination pliers/screwdriver on my key ring for quite a while. I've been wanting to try wet forming, and thought making a fob/sleeve would be good practice before working on a larger project. If I was to do this again, I think I would incorporate the strap into the back piece rather than riveting on a separate piece. I also need to work on getting my rivets to set squarely, instead of sliding off to one side.
  6. Thank you. Yes, the ox blood dye is fiebings. On the resolene, I first applied the dye, let it sit for a few minutes and then wiped off the excess. The next day I applied a coat of neatsfoot oil and let it rest overnight. I then applied the resolene with a slightly damp dauber, dabbing off the excess. I repeated a day later. If the piece is dry, I can buff it with no transfer. But if the cloth is slightly moistened I am getting quite a bit of transfer.
  7. Just recently joined after lurking for awhile, gaining a lot of tips and education. I've been incredibly impressed with the quality of work that I've seen and the willingness of members to share. I appreciate the opportunity to join the community and learn even more. I'm attaching a few photos of some of my first few projects. My largest project so far has been a belt - block dyed with mahogany and then completed with ox-blood. I'm pretty happy with it overall - except I think I left the tail about 1'' too short. I began with the key chains to give me a chance to work on different techniques without consuming so much product. Similarly, I've tried a couple of dog collars for the same reason. The biggest issue that I'm having is dye bleed after sealing with Resolene.
