I would like to build a DIY "box style " speed reducer. I understand the concept pretty well, I am thinking of a 3:1 reduction using a 6: OD and 2" OD pulley. My first question is, if you use 2 fixed pillow block bearings to support the shaft, how do you allow for adjusting the belt tension between the reducer and the sewing machine? I thought of use a 2 bolt flanged bearing and making one of the mounting holes slotted, would need to have same setup on both bearings does that seem like it would work? Also, I see a lot of 6" pulleys rated for 4L belts and I want to use 3L, can a 3L belt work well with the larger 4L pulley? I have seen some pulleys rated for 3L and 4L that's what I'm hoping to do.
