DocDaddy
Posts posted by DocDaddy
  1. First off don’t be so hard on yourself.  I would be willing to bet most people in your town wouldn’t be able to produce a belt let alone a molded pancake holster. Looks good. One tip I would give to help with the stitching is to lay a stitching groove and pull your stitches tight as you go along. Then come back and tap the stitches flat with a cobblers hammer or mallet. Good luck.
  2. On ‎12‎/‎1‎/‎2017 at 5:48 PM, nrk said:
    stitching is nice.
    what is it?
    Slide Holster.  Thank You.
    On ‎12‎/‎2‎/‎2017 at 9:15 AM, Fire88 said:
    How did you do the punisher logo?
    I use a vinyl cutting machine to create my design and then start with light coats of dye around it and use several coats around the decal.  Once I am happy with it, I fade it in to the rest of the dye for the project
  3. 53 minutes ago, alpha2 said:
    Often the seam on the edges can be caused by a too thick layer of glue, or not enough glue... Too thick and it shows because the leather doesn't get close together. Not enough glue and the leather can separate.
    Also, it's important to pound the layers together when you've glued them. Also you can put a heavy weight on the pieces to hold them tight while the glue sets up. Lastly, it may be the kind of glue you are using. If it's any of the commonly mentioned glues on this forum, I wouldn't worry about that.
    I'm fairly certain the issue is glue technique related. Having said that, you might be able to rescue this holster,  (although it's unlikely any non-leatherworker would notice) with numerous coatings of edge paint with a lot of sanding in between coats. Kind of a body filler approach!
    This explains a ton. I am using Fiebings leathercraft cement but I am not hammering it out and I am not weighting it down either. Thank you for the tip!
  4. It is really more of a seam instead of a gap.   Thank you for the feedback. The skull was created with the use of a custom vinyl decal cut out of some scra vinyl I had laying around. My original decal had cutouts for the nose and a ring of stars around the crown of the skull hence the splatter. I plan on creating a skull without these cutouts if I decide to do another punisher skull in the future. I wanted a really low ride  on this one. The belt cutouts are the bane of my existence.  I have so much trouble punching through two levels of leather. I plan on switching to an avenger style on the next one.
  5. Hello everyone.  Just wanted to introduce myself.  I have just recently picked up leatherworking.  Looking to build my tools and improve my work.  If anyone has tips on what tools and items are absolute essentials for starting out, I would appreciate it.  Thanks, Larry
