Content Count
7 -
Calendar
Everything posted by MRknives
Bee knife/sheath
MRknives replied to MRknives's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thank you so much friends. Appreciate the encouragement! -
Bee knife/sheath
Thank you all for the kind words. The handle material is a metallic octagon cast in yellow resin likely a 2 part resin that’s most likely an alumilite product. I purchased the the resin block to then work from. Have played with Alumilite in the past hence the educated guess. Thank you. The brown spacer portion is the side of a piece of vintage micarta. Guessing Westinghouse but hard to tell -
Received the pics back this week of one I had a fun time making (both knife and sheath) combo and using a little darker dye around the edge of some drum dyed leather for the sheath. I probably should have run it along the top edge as well. Beginning two others with slight variations now.
Need help! Canted sheath
MRknives replied to DaveP's topic in Gun Holsters, Rifle Slings and Knife Sheathes
It appears to be a double layered sheaths and just the one loop it’s sewn back to itself. I do believe that would hold well enough -
Thank you! I use Damascus Billets and grind and heat treat my own work. I'm between Sugarland and Houston.
Picked up leather working as a little hobby about a year ago after a decade of knife making. Paul Long has been a great encourager and I'm enjoying exploring some new projects.
Great video and very helpful! The only part I would disagree with after reading much research including Jurach's books on sharpening, would be to use a new stone and never use water or oil for lubrication. Lubrication retains metal filings creating gouges in the edge of your blade slowly destroying your edge (picture something more like a serrated edge being created with lubrication containing microscopic metal filings) I wrote a short blog article summary if interested @ http://www.mrknives.com/blog/2013/09/24/Knife-Sharpenning-Creating-a-Fine-Edge.aspx
