JeffRoseborough
Everything posted by JeffRoseborough
  1. I bought one on Amazon for cheap, fits in a Dremel, and seems to work well.
  2. This is a bit different from what I envisioned but the concept is the same. My first project was a cell phone case and it was very similar to this. I had overlapping pockets on one side.
  3. Thanks for the pattern. It is similar to others I have seen and quite simple to visualize. Basically a bifold wallet with 3 pockets on each side. Back face is wider than the inside so when the wallet is folded it doesn't bind up.
  4. I use lard as it is readily available here in the states. 1bar Ivory pure, 1lb lard, and 1 1/2 cup of water. Boil water and soap together, ad lard, mix and cool. As it cools give it a mix a few times. If it is too thick you can add water. I have a bucket of plaiting soap that is over 2 years old and has yet to go rancid. Old plaiters would use sheep's fat from around the kidneys area (cleanest), render it down and strain it to remove impurities. Then add that to the soap and water. Also added a bit of kerosene to keep varmints from chewing the leather. I've used a few different scented oils like eucalyptus or Tea Tree oil.
