Everything posted by LomaeArts
I am looking at a Singer 111w112 that has popped up in my local area. I looks Ok with a fair amount of paint worn off the table faded badly. However seller says it works well ( we'll see). I like the decent availability of presser feet! I can't find any details on the serial number and am wondering if there is any other place to search other than IMACS?
This sewing machine has become available at a reasonable price, but I am have difficulty identifying it. Can anyone suggest the singer model?
Singer Patcher 29k53 - not picking up bobbin thread
LomaeArts replied to LomaeArts's topic in Leather Sewing Machines
Here's a video of the needle -
I Have GB 29x3 needles and they are aligned correctly. The needles are fully seated in the needle bar. How ever I can't tell if the they too long. Nor do I know if the previous owner used the same needles. Ho do I check the length is correct? -
When I placed my 45k on it pedestool stand, I used an industrial M belt to drive it. over time this has twisted to run an edge inside the groove. I thought I would replace the belt with a round leather belt and souurced some 8mm ( or 5/16") belt (same as my Landis outsole stitcher) but it feels too big. Should I use 8mm or go down to 6mm ( or what ever I have on the 29k patcher)? Thanx Matthew
I have a fair number of bobbins. I created and 3D printed holders for my K6 & 45k bobbins. They are available on Thingiverse if you want to print some more. https://www.thingiverse.com/thing:4910646 https://www.thingiverse.com/thing:4896562
I would like to add a binding plate to my bigger sewing machines. on the 45k, I believe the Guide plate is P/N91168 and the screws fixing the plate are P/N #180f. can any one confirm these are 3/16 x 28tpi screw? What would be the screw needed to attach the binding plate? would these screws also fit the 132k6? Thank you Matthew
I proudly picked up a 132k6 from a local canvas shop the other day. It is in great working order and I immediately swapped out the Japanese clutch motor with a servo motor. Sews 5 and 6 mm saddle leather like a gem.
A local shop has a reconditioned PFAFF 1246 twin needle 9.6mm gauge sewing machine. Is it possible to use as a single needle?
Windows lets me give the real link https://www.universalsewing.com/images2/parts_lists/all/sk4hh86a.pdf
- 18 replies
- singer 46k38
- singer
(and 2 more)
For a 46k38 parts manual, look here: https://www.supsew.com/catalogs-diagrams Search for 46k34.
- 18 replies
- singer 46k38
- singer
(and 2 more)
Ok now it my turn. I am in the process of buying a 46k38 from a private estate. there a little surface rust and the paint has worn in places but Inside / underneath the maching looks pristeen. I need to source needles as the seller doens't have any. when I pick it up I wll add photos. Our main use of the maching is repairing Ugg Boots. So we're looking farward to trying it out
- 18 replies
- singer 46k38
- singer
(and 2 more)
I have a 29k in the shop. the needle retaining screw head has seen better days I tried buying a screw from ebay only to discover it is too small. So may I ask What is the thread of the screw that holds the needle highlight in the picture? I would like to try and source something locally.
I need to source a thread reel to try the spool post. I don't this is my issue, but will investigate later. While I realise these are old and outdated, is it possible to buy spares? I would like to buy the following parts: 55025, 55027, 55525 & 55527
Yeah, it hwas a display item in the shop I bought. I like a lot and if I can make it reliable will using on hand made leather sandles.
Thanks for the replies. I have included a sample I was doing before it quit on me. Constabulary: that is a good explanation. I am stiching 5.5mm bridle leather that is a bit softer that sole leather. I am starting to think i have a tension issue as I fine the tread slides under the trnsion discs and jams. jimi: The bobbin tension hasn't changed, but is pretty tight.
I started to try stiching with the Pedersen Model 308. After repacking and adjusting the tension spring, i got some great stiches. Then is stopped stiching - IE the top tread doesn't look the bobin. I note the shuttle and bobin as very slopy, and wonder if it is the cause of the issue. changing the needle didn't help.
Constabulary - PM sent, those images are so good. RockyAussie - yeah I have that manual. Ok UPDATE. I degreased and oiled the stitcher. I threaded it with 150D waxed thread as that seems to the size that was on the machine. Initial observations: it is super easy to use The waxed thread works well the needles that came with it are #6 and lots of #7. these are big. the stitch length is about 4 to 6 mm the Tension needs attention I like using more than my Landis model 12 due its simplicity. The photos below show the unit on my dining room table
I recently acquired a Pedersen Model 308 Sole Stitcher. I am yet to try stitching as it is cocered in years of dust and grime. I have read most of the threads here. As well as a manual I found. My meachanism looks great and works sell. My reading shows: the bobin thread has to be waxed the top thread is not waxed you stitch Welt up However what is not clear ( lack of detailed picture) is: How to adjust the bobbin tension, How adjust the stitch length Does the thread need to be waxed Do I need to grove the sole Any assistance on these will be much appreciated.
Landis still sell these, but they don't post the cutter details. Landis cutter blades. I wonder if a Landis 5in1 owner could make some measurements and take some photos. My unit screws of using 1/2-20 UNF left hand thread.
Once cleaned and oiled the basic trimmer 6mm hard heal material quite wheel. I don't have any soft rubbery sole material to try out. The cutter should be 1 to 1.5mm bigger. The good news is the shop I acquired has two others that work reasonably well, so if I can't buy repacement blades, I will get 4 made up. All the drive wheels ( lower cogs) are in good condition. I can produce Cad files to send to a CNC lathe
I have acquired two differenct model of ESTO leather and plastic trimmers. I haven't found any information on the web on ESTO products. Thje trimmers need new Cutter (top) blades., while the scorer (bottom) is OK. Having cleaned out many years of grime and dirt, one cuts 6mm heal material real well, the other is way to worn. Does anyone know any about ESTO gear and are spare parts available? I will up load some photos shortly.
