KooperLee
Everything posted by KooperLee
  1. I've also tried using the Craft Plus(Tandy has this similar press) to set the solid copper rivet and burr earlier. And it worked, too. Here are the photos; I can also make a video if you guys want me to.
  2. Hi, everyone. I'm not sure if this video I made can help. But I haven't set my kick press correctly. The rivets and burrs are set unprofessional and there was an error while installing. I can do it right and also make another video if you want me to.
  3. Hi Treesner, recently I launched my new designs - double-sided rivets on my site http://dot-gas.com/jeans_rivet_p1.html I do flat cap and convex cap for the moment, both available for size 8MM and 9.5MM, and they can go with tacks in 3 available lengths 6.5, 8 and 12MM. They are made from the high-grade brass material and designed for high-end products, a perfect combination of appearance and functionality.
  4. Hi bradkincaid, sorry the link I posted above is wrong. The correct link is http://dot-gas.com/snap_fastener_p1.html
  5. If you want not only the snaps hold your products firmly, but also the snaps look professionally well-done. Then you might need a special setter people also call them dies or die sets like what I attached. But to apply the die sets, you also a press. You can try this post http://www.dot-gas.com/wordpress/?p=759 if you want to get more idea.
  6. I've never seen any solid snaps and I am afraid there isn't... because it is not the way how they are normally made, you know the processes like drawing and stamping... when it really comes in solid then there must be die-cast.. but I have no idea how it works like a normal brass snaps... but which is for sure that the thicker brass material the factories use to produce the snaps, the more durable the snaps they are and stronger. Since I don't know what type of snaps you're looking for, or maybe you can browse this webpage http://dot-gas.com/garment_snap_fastener_p1.html and get some ideas KL
