I got my first machine a few weeks ago, and am just getting it set up. First of all, let me disclose that it's a Singer 95-1.
I am fully aware that this machine is in no way shape or form designed to sew leather.....yet. The reason I bought it was that it was on a table that's in excellent condition with a consew clutch and westinghouse motor.. I got the whole thing for $60, and figured it would be useful to have the table so I won't need one if I found an ideal machine without a table.
Being a machinist and a tinkerer, I figured I'd use parts that I have laying around the shop to see if I can get this thing to at least be usable for leather and other heavy materials. So far I think it's actually doing pretty well. I put a 2" pulley on the clutch, and a gigantic 8" pulley in place of the balance wheel and a v belt instead of the leather round belt it came with. The machine looks ridiculous considering how small it is in relation to the pulley, but it is also very effective for manual stitching. Whoever decided that the top shaft on this machine should be .540" in diameter instead of a standard fractional size, made things somewhat more difficult. Just had to bore out the pulley hub and spacers from 1/2". I can now do about one and a half stitches per second with careful clutch control and with the flywheel inertia from the large pulley and the additional torque, it doesn't even hesitate punching through thick material. It doesn't seem to have an issue with #69 bonded nylon, and I think I can get it to work with #92 but haven't tried it yet. Good enough for wallets and camping gear.
The issue I'm having is that it uses 88 x 1 (1128, DA x 1, take your pick of sizing convention) needles. I haven't even been able to find a leather point needle of that type, and selection is very limited. I bought some common 110/18 needles to study a bit.. It seems to me that the critical dimension is the distance from the end of the needle bar to the eye of the needle. The points of the needles in the 110/18's extend slightly further below the eye, that might cause a timing issue. The needle bar on this machine is a simple .250" rod with a needle socket on the end and a set screw. The 88 x 1 needles have a .0625" (1/16") shank, while the common needles have a 2mm shank. It would be easy to drill out the socket to the correct size and depth for the common needles to get the eye in the right position. Or I could make some new bars so I'll have an assortment.
Is there any reason this can't be done? And if it can be done, what type of needle should I be designing the needle bar modification to fit? Thanks, I hope this isn't a silly question. So far I only have about $90 into this machine and some time. As usual the problem solving aspects have been pretty enjoyable.
