I’ve got the head all back together clean oil and new grease. All seems smooth . It’s still not sewing well. The top tension is as loose as it can be. Bobbin tension is good. It stitches well on flat thin material. As soon as I put it under a load it skips stitches. I’m sewing  a lot of synthetic leather  in tight areas on hockey gloves.
	There must be instructions somewhere to reset all adjustments after a good servicing?  I’ve checked the timing , tension, proper thread and needles. I even found some original singer needs in the shop!
	To eliminate an error there I put in a new singer needle. The stitch length adjuster was traveling so i checked the parts manual and righted that.
	ive sewn on this machine for many years doing the same jobs.  it just doesn’t feel the same. It feels like the foot is floating and as soon as there is the slightest need to go around in a tight spot it skips stitches or it won’t sew at all. I’ve tried more pressure on the foot and I know to adjust the knurl nut  to a lower setting reset the tension if necessary . I have put on a different but not new foot.
	getting so frustrated so I thought I’d try a thicker piece of leather. Changed all the settings required. Wouldn’t make one complete stitch!  The strap leather pulls up with the needle. So I put some oil on the material no difference.  Any thoughts are appreciate.
	i live in Calgary Alberta Canada
	cheers
	Elaine
