grasshopper
  • Content Count
    7
Everything posted by grasshopper
  1. How far does the metal center shaft extend into the round burnishers? Karl
  2. Bree thank you for all your help, the information you provides helps ALOT! Karl
  3. Hi what finish do you guys recommend for a double layer gun belt? I dyed the outter layer with feibings black dye and the inner layer left natural. Would you put a different finish on the inner layer opposed to the outer (top layer) because of the exposure to perspiration. What about the flexability of the finish, is Acrylic Resolene flexable or will it give a crack/ wrinkle look? Thank you. Karl
  4. Would a burnishing wheel made out of metal (aluminum, brass, stainless) work or does it have to be made of wood? Thanks! Karl
  5. Hi, what finish do you suggest for finishing a double layer gun belt? Would Acrylic Resolene be flexable enough and would it give a crack/ wrinkle appearance as it wears or breaks in? Thanks! Karl
  6. Nice job, is that two layers of 7oz.? Did you skive the blank down yourself or weaver skived it for you? What was the original weight of the belt blank? How did you keep the inside belt from not getting black from the dye? How did you dye the edges so neatly without dyeing the inside belt?
