Klover
Everything posted by Klover
  1. I haven't adjusted the presser foot at all, but I will definitely take a closer look. I'm using the needle that the machine arrived with. It's a 794 S size 25 needle. I increased the top tension and am getting slightly better results, but the stitching seems abnormally tight, like it's sinking too far into the leather. Going to do some more tinkering today.
  2. Thank you for the input! I'll definitely check out those images/videos. And thank you for mentioning the thread slippage. I hadn't even thought about that, but I will keep it in mind!
  3. These are awesome!!
  4. Hello! My Cobra Class 4 just arrived. First machine, and I'm trying to get the tension right. Will usually be sewing 5-6 oz - 10-12 oz, so I'm hoping to hit the right tension that can be used for most of my projects so that I don't have to mess with it too much. Will probably stick to 277 bonded nylon thread. The top stitch looks okay for the moemnt, but the bottom stitch looks whacky. Should I loosen the bobbin/bottom tension a little bit? All I've done so far is loosen the top tension about 1 full turn (achieved through small increments). I turned both top tension knobs.
