Posts posted by HavnerDesign
@Wyowally I am impressed. Nice looking sling and a smart solution with the leather strips for grip. Care to share a close up photo of the strips?
On 9/20/2022 at 7:37 PM, chuck123wapati said:
a lot of folks put a thumb hole through or a loop on the inside to hang their thumb in so the sling wont slip around.
Yes! I've seen thumb holes and they are very clever and add a nice little detail to the sling if they are neatly done with stitching around the hole and so. Working on a custom sling right now that somebody ordered and will make a thumb hole as a surprise feature i think!
On 9/20/2022 at 11:05 PM, TomE said:
This product is a synthetic rubber (butadiene) for sealing the flesh side of leather. I use it mixed 50:50 with water and work the first coat into the leather with a glass slicker then apply a thin second coat. However, it dries as a smooth nontacky finish (like the label says). It seals out moisture and seems to be durable. I use it on bridle pieces that are split thickness as a replacement for the mossback finish of full thickness bridle leather.
The BT639 might not suit your purposes. What about sewing on a liner of rough out chaps leather? https://www.hidehouse.com/Leather/Pearl-Split-Cow-Split-Grain-Suede-Finish-PE10-P.asp
Thanks! Had never seen this product. Does it make about the same result as Tokonole or Gum trag? And yes, a leather liner of some sort is a good solution!
On 9/21/2022 at 5:15 AM, GatoGordo said:
I line the back of the sling with suede. It provides grip and a padding for the shoulder.
Yes I have also done that in the past, it works ok and seem to last over time. This time I was trying to evolve and challenge myself to find alternative, and possibly cheaper, solutions. However, suede will likely outlast any manmade material...
On 9/20/2022 at 6:33 PM, tsunkasapa said:
Neoprene. We use it on harnesses for sled dogs. It is the same stuff 'mouse pads' are made of and comes with or without the fabric facing.
Nice tip, thanks! That will also serve as padding for the shoulder.
On 9/20/2022 at 4:28 PM, Gezzer said:
Look at router pads or maybe even shelve liner , might be something you could use .
Hope you find something !!
Very clever, would never have found those. Thanks!
Hi,
I am new to the forum, but have done leather work for a hobby for some years.
Among other things, I make leather gun slings for hunters, and I want to find something to add as anti slip on the part of the sling that is in contact with the shoulder. A hunting rifle is quite heavy and it is annoying when the sling and rifle starts to slip down your shoulder and you need to constantly adjust the sling to get back up on your shoulder. Can anyone recommend liquid latex? Will it stick properly to leather? Will it last over time? Or is there a better solution? I have found self adhesive anti slip-labels or stickers that are made for handbags and other smaller shoulder bags, but I don't reckon they will last very long on a rifle sling... Is there any kind of rubbery band or patch I can sew on to the back of the sling?
Anti slip for shoulder strap / gun sling?
in How Do I Do That?
@Gezzer I actually got a rubbery padding material from a professional sling maker. I asked him what he used and he gave me one to try, for free. (Will upload some photos here shortly). It works, but I am very keen to "invent" my own solution.
Next sling will have router mat on the back. Thanks again for that tip!
