BlueOx
Everything posted by BlueOx
  1. I really dig those, makes me want to make a few as well.
  2. That looks extremely clean. I'll be interested to see how it ends up after being in the other shops hands. Always thought the rhino was a neat gun anyways, not quite as interesting as the Mateba autorevolver it's based on but still interesting.
  3. Picked up an older singer machine, got it up and running and used it to make some booties for a friend. Wish I had used a softer leather, getting them inside out was painfull. But I think they turned out okay. Made with 2ozish veg tan.
  4. A relative commissioned a belt from me, and wanted it lined. Would be my first lined belt, tried my best to make it look good and don't think it turned out to shabby. Veg tan 1 1/2 in, 8oz with 2oz liner. (The buckle I had ordered didn't work so I had to use a backup that doesn't quite match the keeper.)
  5. BlueOx
    1911 Holster
    I burnished the edges with tokenole. And yeah it's veg tan for the liner as well. Two 4 oz pieces back to back. With the reinforcement piece being 8 oz off a random leftover I had. I got the pattern from Springfield leather Co in one of their packs.
  6. BlueOx
    1911 Holster
    Really trying to get better at making holsters, this is my fourth and I think I'm starting to finally be happy with the results. The coloring is intentional with the slight fade, airbrushing the dye on has made it much easier to achieve. I do leave the liner natural other than a resolene coating.
  7. Finished a second mousepad that's been on my to do bench for months. Both backed with 1/8th neoprene for heft and to help it not slide so much. First one I made a few months ago: And the one I just finished (sadly the leather quality is a bit lower) : Finished with a resoline coating. Both were airbrushed with dye by my wife as her first projects. Honestly I think they both turned out really well.
  8. As a project for a relative, I made this replacement piece for his binocular Harness. The original is a rubber like material, and a little short for his longer torso. While it isn't perfect, I'm fairly happy with how it turned out.
  9. I'd say you were right about the tension, the holster is 10 oz with an additional 2 oz liner. But the loop is just 10 oz, so it may be that very slight different causing the issue occasionally. I'll have to double check that before I go for the second attempt.
  10. I figured the more ambitious the project, the better excuse I'd have when I failed 😅 Just got lucky that it turned out better than I expected.
  11. Thank you, the few people I've shown didn't notice the stitching issues. So you're probably right that I should just not point it out. But since I made it it seems so obvious. So far it does carry a 45 1911 pretty well, even with my extra weight. So I think the height does help a bit.
  12. While working a commission for a company, one of the employees asked if I could do holsters. I had never made one so I did my best to find out if I could. I see many mistakes in my part, especially messing up the last bit of stitching of the entire piece. But for a first try im pretty pleased with myself. I'll have to use it for awhile before I'd be comfortable trusting one I made enough to sell though.
  13. Thank you. It honestly was a fight to keep it matching, I could only do about 4 stamps on one side before I had to flip it and try to get the other side relined up.
  14. Thank you for linking that, I'll have to give it a good read and see how much better I can make the next project.
  15. Thank you, and I did. But looking closer probubly not as much as I should have.
  16. Wanted to show my first attempt at a belt with some tooling involved. I see plenty of mistakes, but I'm pretty happy with how it turned out. Especially since it's a donation for a school auction. I welcome any critiques and/or suggestions on how to do better. Thank you.
  17. BlueOx
    Cigar Cases
    Thank you, and I'll have to keep my eye out for old fire hoses. I'll definitely give the canvas a try in the meantime. As for my molds, I'll add a pic of them. For the larger section I end up using a slightly larger diameter and a little wider pocket as well. Edit: After I put the molds into the leather I use a vacuum bag to help mold them and let them dry a little.
  18. I've been tinkering with modeling basket weave into my prints and I wanted to share what I've managed and see if anyone else had had any luck. Hopefully this is the right category. First is my favorite, the entire stamp was 3d printed with the basket weave background being one of my most recent designs that I think has worked. Next is one I did as a one off for a friend, it uses one of my first patterns. Which I used to make a card sleave for his wife. I did some testing with an arch style. And just recently I'm working on a fairly ambitious idea that is far from being complete. As a note, all of these have been printed in resin. I find it can do the small detail a lot better.
  19. BlueOx
    Cigar Cases
    Wanted to share the progress from first prototype, to the first one I'm fairly happy with. The first one was more than a bit rough, and was made using my first attempt at making a mold. The rest were made with one I modeled and 3d printed and turned out a lot better in my opinion. Still not sure what the best way to finish the edges would be, especially the opening sections. Any feedback is also appreciated, thank you.
