Members indypbear Posted October 24, 2007 Author Members Report Posted October 24, 2007 Thanks to everyone :flame: . great info. I spoke with George Hurst today and he recommended the Paasche brushes but was open on the compresser. He lives in an apartment so semi-quiet is important, not silent. Glad to see several of you at the IFoLG this year. Got faces with e-mail names now. Hope to see and meet more in Columbus and Indy. That was my stompin' grounds for 53 years. Keep showin' your projects. I learn a lot from them. I'll be doing more and post some fro critique later. Indy transplant to TX JKK Quote
Members Patrice Posted October 24, 2007 Members Report Posted October 24, 2007 I'm also looking for an airbrush, and migth be buying a paasche dual action. But, iw ould like to know what is the big difference between the VL, VLS and the Millenium Of course, i read some advice on the web, but if an owner of a paasche VL, VLS or millenium could talk about his machine, i would appreciated it! Quote Patrice
Members SmilinJim Posted October 25, 2007 Members Report Posted October 25, 2007 Hi Patrice Not an expert but the VL and VLS are basically the same. The VLS has a swivel connector for the paint bottle hence the 'S'. I don't know the Millenium. I just started using the brush again, never was real good, but works great with stains and stencils. I have a small Bager and the VL which is considered a large airbrush. My kit included 3 tips for a wide variety of spray sizes. Got a compressor at a yardsale for $5.00 and another at a thrift store for $2.00, needed minor repair. Jim Quote
Members Patrice Posted October 27, 2007 Members Report Posted October 27, 2007 Thank's a lot Smilin Jim! I'll be ordering a VLS for christmas, as this will be my present from my parents. Here's a Ebay seller from wich i'll be buying my kit: http://stores.ebay.com/TCPGlobal-AutoBodyD...4QQftidZ2QQtZkm This guy seeling a lot of stuff! Glad i can share this seelr with you! Quote Patrice
steveb Posted October 28, 2007 Report Posted October 28, 2007 If one has a perminant workstation, one could put the 'pressor in a cabinet with sound deadening stuff inside it. Shag carpet maybe or foam. Or does that not work? Just reaching out in the far recesses of my creative mind here. The trouble would be that the compressor needs air circulation and inlet air. They often tend to overheat when running constant. i keep a 30gal compressor under my bench in a "sound proofed" (sort of) cabinet for air tools an powering a bike lift- it breathes fine enough through the hole i cut in the door of the cabinet to run teh hose through- but it does get hot if it is kept on for any length of time - for my airbrushes i use the cheep paasche pancake compressor - works well enough and i have 2 paasche VL's - they are the workhorses of the airbrush world - i clean them real well everytime i use em, so they have lasted of course YMMV steveb Quote
howardb Posted November 22, 2007 Report Posted November 22, 2007 Echoing the scuba tank idea... There is an article in this month's Model Railroader about using a portable CO2 tank as an airbrush source. The tanks are available at home stores (Lowes, home depot, etc) and are designed to run air tools portably. I'd check on refills, etc. but it sure sounded like a grand idea. Brent Quote Brent Howard CALG, HLG
Members MatthewD Posted November 22, 2007 Members Report Posted November 22, 2007 Okay now you got me thinking.. I have a portable air tank.. I wonder what I would have to do to it to be able to run my air brush off of it... Quote
Members Patrice Posted November 22, 2007 Members Report Posted November 22, 2007 (edited) I received my a irbrush kit this tuesday! I bought the millenium kit : http://cgi.ebay.com/PAASCHE-MILLENNIUM-AIR...oQQcmdZViewItem I'm really glad about this purchase. I plug the whole kit and everything was working great! I choose this kit because the barrel is offering a thinner grip. The only downside is that i'll have to wait t'ill christmas beacause the kit is my gift P.s. The compressor is very quiet! Edited November 22, 2007 by Patrice Quote Patrice
Members Cascabel Posted November 4, 2013 Members Report Posted November 4, 2013 The best and cheapest solution is to use the compressor out of an old refrigerator. They are pretty much totally silent, and will serve nicely for an airbrush, if that is all you need it for. You will need to feed the output through a small tank, like an old propane or freon bottle to take the pulsations out of it. The small "silent" compressors sold commercially are quite similar, but a lot more expensive. You will also want a regulator on the output side of the tank. The tank is absolutely necessary, as the refrigeration compressor is a single piston type. A compressor from an air conditioner will also work nicely. Either way, you leave the compressor inside its original housing, which helps to keep it quiet. Put an intake filter on the inlet side to keep the dirt out of it, and connect the output side to your tank. You can tell inlet from output by feeling the openings of the pipes when you connect the power. These things pretty much last forever, as they are sealed up in a housing free from dirt. Quote
