Members Thescandall Posted April 28, 2022 Members Report Posted April 28, 2022 (edited) It sews great but leaves a bad skid mark. 111w155 alternating presser foot not doing squat. Took a video. By the way this new table and motor I built is really nice. Talk about control. Any way. What the heck is going on here. Edited April 28, 2022 by Thescandall Quote
Members Constabulary Posted April 28, 2022 Members Report Posted April 28, 2022 I´d try this - loosen this screw (maybe its loose already), rotate the hand wheel toward you until the inner foot and the tip of the needle arrive at throat plate level at the same time. Then tighten the screw again and check if it works. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Thescandall Posted April 28, 2022 Author Members Report Posted April 28, 2022 10-4. Will try it tomorrow when I get back to the ranch. Quote
Members vovo Posted April 29, 2022 Members Report Posted April 29, 2022 Mine is similar actually. the presser foot is not lifting. I just added a video too. Very interested in your solution if you manage to get it resolved. Quote
Members Thescandall Posted April 29, 2022 Author Members Report Posted April 29, 2022 Vovo. I searched your threads and found yours. It led me down a worm hole to a bunch of very useful info and videos. That singer manual is awesome compared to the military ones I have. Also Uwe and Constabularys knowledge is super valuable. Hope to sort things out this afternoon when I get back to the ranch. I will post up later with a video of the full machine, table and motor set up I have done. It’s my first one and I can already feel the addiction setting in. I just need to find another cool machine to mess with now. Quote
Members Thescandall Posted May 1, 2022 Author Members Report Posted May 1, 2022 On 4/28/2022 at 7:40 AM, Constabulary said: I´d try this - loosen this screw (maybe its loose already), rotate the hand wheel toward you until the inner foot and the tip of the needle arrive at throat plate level at the same time. Then tighten the screw again and check if it works. Expand That was the problem. It lifts correct now. It needs to be a little higher while sewing but now that I followed the worm hole to the older posts I gathered a lot of useful info. And the actual readable singer manual is great. All the other ones I have are blurry and not complete. Thanks. Quote
