Members Constabulary Posted May 13, 2022 Members Report Posted May 13, 2022 There is so much cast iron you will not overheat it with a heat gun, not even even with a gas blow torch.... you don´t want it "red glowing" just hot enough that the bushing can break free when you tap it. Is there probably a 2nd screw holding the bushing? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted May 13, 2022 Members Report Posted May 13, 2022 May be a second screw holding the bushing C but should not be. In my opinion, the bushing should be flush with the right side of the cast piece it is in. Looks like it can go about 1/8" from left to right! glenn Quote
Members Damas Posted May 18, 2022 Author Members Report Posted May 18, 2022 Sorry for late answer, I have been away for a few days. So I compared both machines and the bushing is moving on my 132k10, in both direction, when gently taping on it, once screw #4 is loose. There isn't any second screw. The second hole is where comes the bobbin case retainer ratchet I had to remove in first place in order to access screw #4. Both machines are identical twins for this mechanism. So my guess is @Constabulary is right, probably some rust I will have to stress with heat to unlock that bushing. I'll try that and keep you informed. Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1 and 069 - Pfaff 545 - Pearson #6 - Hightex CB3200 and CB243
