Members crazytailorlady Posted May 21, 2022 Author Members Report Posted May 21, 2022 19 hours ago, johnnydb said: Curved needles and awls are nice...but truthfully I've never gotten the hang of them. If you are making a standard bicycle water bottle holder for drinking while going down the road that attaches to the frame.... You really don't need curved awls and needles. I'm unfamiliar with the pattern but I am familiar with the bottle and setup. Personally I'd use veg tanned framing of the piece that was wet molded to the shape and then glue on chrome tanned and make a visible seam in the veg tan. Don't forget the attachment straps....and I'm unsure about using snaps vs buckles vs velcro. It's gotta fit snug to keep from slipping. Have fun! Sounds like a great project! Thanks on the helpful info. I'd be glad to avoid curved tools at this point. Still getting a hang of the normal ones. Quote
Members Tugadude Posted May 21, 2022 Members Report Posted May 21, 2022 9 hours ago, crazytailorlady said: I guess I was vague there. I wanted a stiff, all leather (no wires) cyllindrical holder with straps so I can secure it to the tube, though im still deciding wether to put it on the seat tube or the downtube. I want it to fit about half of the bottle, maybe a bit more. I have some thick, stiff veg tan to work with. Don't discount the "easy way" and that is to just use a circular wooden bottom and then tack the leather to it. Not saying it is better, just easier. You can stain the wood to match and nobody will be the wiser. And it helps to keep the shape of the whole affair. Just a thought. Here's a variation, but just a basic handlebar bag. Then there's this style, which I'm not hugely fond of, but I guess it works...don't know about using it for a single water bottle either...it would work on the seat tube which is basically vertical. Quote
Members crazytailorlady Posted June 3, 2022 Author Members Report Posted June 3, 2022 Hey everyone, So I used the method applying the butt joint and the box joint to make the holder itself and it turned out great. I was proud of it. But, I messed up. There is a reason bottles mounted on tubes go into wire/metal cages. The straps on mine would loosen under weight and slip down or sideways. I spent literall hours trying to fit it differently to no use. So my project was a grand failure. Still, thanks for the advice, I did learn new stitches and a way to sew round which is what the post was about. Quote
Members crazytailorlady Posted June 13, 2022 Author Members Report Posted June 13, 2022 Hey guys! After thinking it over I decided to try and fix what went wrong which was faulty leather straps and I did it. Head over to my post in "Show Off!" thread to see the completed project. Quote
