Members DarthSplay Posted July 8, 2022 Members Report Posted July 8, 2022 Good afternoon everyone. I am new to leather working but have a few projects I am getting ready to start and would like to make sure I get the materials I need that will work. My first question is when it comes to dyes. If I make an item that will come in contact with sweat and water is it better to do vegtan or chrome tan? I want the least amount of bleed possible. Thank you very much in advance. Quote
CFM chuck123wapati Posted July 9, 2022 CFM Report Posted July 9, 2022 i don't do chrome tan so cant offer any advise as to the different types and dye retention but you may need to be more specific to get a good answer, getting something superficially wet from a sudden rain storm is much different than say a collar for a Labrador retriever that may swim in it for hours. you may try perusing the adult section for answers. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Dwight Posted July 9, 2022 Members Report Posted July 9, 2022 On 7/8/2022 at 5:09 PM, DarthSplay said: Good afternoon everyone. I am new to leather working but have a few projects I am getting ready to start and would like to make sure I get the materials I need that will work. My first question is when it comes to dyes. If I make an item that will come in contact with sweat and water is it better to do vegtan or chrome tan? I want the least amount of bleed possible. Thank you very much in advance. Well first of all . . . if you were making a cape for batman . . . it would not make much difference . . . a bracelet for a 5 year old might. What are you interested in making . . . holsters . . . belts . . . purses . . . hats? May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members DarthSplay Posted July 10, 2022 Author Members Report Posted July 10, 2022 17 hours ago, Dwight said: Well first of all . . . if you were making a cape for batman . . . it would not make much difference . . . a bracelet for a 5 year old might. What are you interested in making . . . holsters . . . belts . . . purses . . . hats? May God bless, Dwight lol Thank you for that Dwight. I am looking to make an adult bracelet so to speak lol. They are into alternative things lol. So it will be in contact with skin a lot and I am planning on using deer skin or goat or something along those lines for the liner and was hoping that the dye would not bleed. Quote
Members Dwight Posted July 10, 2022 Members Report Posted July 10, 2022 Actually . . . either one will work for what you want to do . . . chrome tanned leather is sometimes used for gloves . . . as it holds up to weather a bit better . . . Veg tanned leather is more for things that will be formed to a certain shape (holsters, sheaths, etc) or for stamping (saddles, belts, etc). If you were going to get a tan / brown / etc . . . putting it out in the sun will turn it about as brown as you want . . . with no problem of dye rub off. If you want black . . . vinegaroon does a good job there . . . no dye rub off. Stay away from USMC black from Tandy's . . . it rubs off for the first 100 years or so. A light coating of Resolene will stop rub off . . . but can be rough on the skin. Diluting the dye with solvent . . . and several doses of the diluted dye will also reduce run off. But if the person is sweating profusely . . . you're on your own . . . that's a tough one. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members DarthSplay Posted July 10, 2022 Author Members Report Posted July 10, 2022 1 hour ago, Dwight said: Actually . . . either one will work for what you want to do . . . chrome tanned leather is sometimes used for gloves . . . as it holds up to weather a bit better . . . Veg tanned leather is more for things that will be formed to a certain shape (holsters, sheaths, etc) or for stamping (saddles, belts, etc). If you were going to get a tan / brown / etc . . . putting it out in the sun will turn it about as brown as you want . . . with no problem of dye rub off. If you want black . . . vinegaroon does a good job there . . . no dye rub off. Stay away from USMC black from Tandy's . . . it rubs off for the first 100 years or so. A light coating of Resolene will stop rub off . . . but can be rough on the skin. Diluting the dye with solvent . . . and several doses of the diluted dye will also reduce run off. But if the person is sweating profusely . . . you're on your own . . . that's a tough one. May God bless, Dwight Awesome thank you so much. So when I go to do my mando kit then I should use veg tan because I will be wet forming it to fit me? In that case, can I still dye it afterward or does it have to be dyed first? Quote
Members Dwight Posted July 11, 2022 Members Report Posted July 11, 2022 Actually you can do it either way . . . I have two different Roman armor pieces (front and back and apron) . . . the black one is molded specifically for me . . . and will be used in a one act play in our church . . . as Cornelius the centurion. I molded it first . . . then dyed it. Molding it first gave it the typical shape I wanted . . . but by later dying it . . . it became wet again . . . and when it dried the second time . . . it was a bit more solid . . . a little harder. I'm just in the process of decorating it . . . the picture shows my inspiration for it . . . Anything you mold that way that you want to be seriously hard . . . dry it with heat. DO NOT go over 140 deg F . . . I have a drying box I use for holsters and stuff . . . they dry HARD . . . Anyway . . . have fun. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members DarthSplay Posted July 11, 2022 Author Members Report Posted July 11, 2022 14 hours ago, Dwight said: Actually you can do it either way . . . I have two different Roman armor pieces (front and back and apron) . . . the black one is molded specifically for me . . . and will be used in a one act play in our church . . . as Cornelius the centurion. I molded it first . . . then dyed it. Molding it first gave it the typical shape I wanted . . . but by later dying it . . . it became wet again . . . and when it dried the second time . . . it was a bit more solid . . . a little harder. I'm just in the process of decorating it . . . the picture shows my inspiration for it . . . Anything you mold that way that you want to be seriously hard . . . dry it with heat. DO NOT go over 140 deg F . . . I have a drying box I use for holsters and stuff . . . they dry HARD . . . Anyway . . . have fun. May God bless, Dwight Awesome thank you again. I would love to see pics when you are done. Quote
