Members trast Posted April 24, 2009 Members Report Posted April 24, 2009 Thanks for starting this topic. This has been on my mind for a while as well. I would like to create my own make shift stamp, but I want to create one that's at least 16 inches square. I'm hoping to create texture to place on pieces of leateher to be used for a bag. There's an existing texture I like that I saw on a glass panel. I basically want to transfer that texture onto several panels of leather. I imagine I would start off by casting it with some plaster, but not sure how to get that cast texture onto a metal surface. I'm curious, if I were to buy some resin and poured that into a plaster mold wether or not that would be strong enough to cause an impression in the leather. Any ideas? Thanks Quote
Members TTcustom Posted August 13, 2009 Members Report Posted August 13, 2009 I thought I read somewhere that Al Stohlman made his own stamps from nails and such. That gave me a start to try making my own I only have one design I made that I like. I use the big timber spikes from Home Depot and they are only ~$0.50 so learning and experimentation has been fun. but now I want to make my own "mongo" beveller for those long gun and kilt belts. I will try to remember to post some pictures of the goofy lil stamps I have done so far. On the staining; I have not seen too much of that but I only have just started making and using stamps of my own manufacture. Oxalic acid works well in removing stains, but that may have already been mentioned. Quote I am fifty years old and I have always lived in freedom; let me end my life free; when I am dead let this be said of me: 'He belonged to no school, to no institution, to no academy, least of all to any régime except the régime of liberty.' "What we need is more cowbell!"
Members Flicker Posted November 19, 2009 Members Report Posted November 19, 2009 Excellent thread, pushed me over the edge to try my hand at making my first stamp. I have only seen stamps on the internet so the first thing I had to do was to measure on my computer screen what the relation between length and width should be. I found some nice examples of stamps and decided to go for a single rope configuration close to what Barry King makes. The tools: A Dremel (saves a lot of elbow grease) with different cutting wheels. Sandpaper (400 grit, 1000 grit). Two small files, a triangular and a flat. A stainless bolt. Hearing protection. Safety glasses. So from this: I transformed it to this: It is not perfect (I am not Barry King ) but good enough to make me want to keep on making my own stamps. I am going to work on the “teeth” and make them a bit smaller so I get an even better shading effect. I am very satisfied knowing that if I have the time I can make most of the stamps I need. My leather crafting skill is just at a beginner level but I would definitely try something more advanced than a regular basket weave pattern in the future. To anyone hesitating to start a project like this: This is the first item I have ever made in steel. I have no education in producing stuff. If you plan on doing something like this instead of buying a stamp, try it! Take it easy, go slow with the decisions on how to make the next cut. Leave one or two tenths of a millimetre as a margin when you are cutting with your dremel (might sound small but in no time you will notice deviations that small). Remove the rest with files and/or sanding paper. Take a lot of breaks in between cuts so that you always plan ahead. And do not forget your safety glasses and hearing protection. I will take the opportunity to thank Chuck Barrows and Bob Park, for their excellent tutorials on how to sew leather and finish it properly. A big thank you also goes out to the nice people in this forum giving a lot of advice to newbies like me. Without you I would probably have been stumbling in the dark for years before achieving any results worth mentioning. I will post some pictures of my work in the future, together with a proper introduction. Now where is that link so I can order some pitch and start brewing my own thread wax. I believe I am hooked. /Juha (Sweden) Quote
Members Spider Posted January 10, 2010 Members Report Posted January 10, 2010 WOW!!! JUST WOW!!!! Love everyone's creativity. Quote From the insane mind of SPIDER... http://spiderflesh.com Myspace: Spiderflesh Facebook: Spiderflesh George
Members shehog Posted January 10, 2010 Members Report Posted January 10, 2010 [/font] Making your own tools 12-8-07 Tools I used for this project Bench grinder Mill file Coarse emery cloth Medium emery cloth 600 grit wet/dry sandpaper 1500 grit wet/dry sandpaper Rag wheel on bench grinder, with Ryobi stainless polishing compound Rag wheel on hand held drill with white rouge Brownells checkering file – 75 Lines per inch Hacksaw (to cut the threads off) Magnifying glasses I work on tools away from my leather bench… you don't want metal filings on your bench or on your leather. For this project, I am going to make a Sheridan style thumbprint. Pear shaders and Thumbprints are easiest to make because they relatively easy, and I, for one, like to have a variety – different sizes, long lined, cross lined, cross hatched, etc., and if they are slightly different shapes, so much the better. Thumbprints have a flatter bottom and are not generally walked like a pearshader, so this particular tool is pretty flat, but make it any way that suits you. Also, many thumbprints don't taper to a point on the end, and are used essentially as two different tools – each end is a different size and can be used as needed. However, I like having a more tapered end that will fit into the end of my "stickers" or "vines", whatever you call them. Leaf liners and center liners are easy too – they look flat on the face but have a slight curvature. Bevelers have to be shaped right or they leave tracks, and you want you different size bevellers to have the same angle, so they are a little tougher, but not too bad. For the thumbprint in this project, the general process I followed is: 1. I use stainless steel bolts, at least 5.5 inches long (I have started using 6"). I typically use 3 sizes – ¼, 5/16, and 3/8. The smaller ones are less than $2 each, and the larger are just over $2. You can use regular bolts or nails or anything, just check for corrosion before you use it – just stamp it on some scrap. I used regular zinc covered bolts for a while, and they work just fine – I have several that are part of my regularly used tools. 2. Leave the bolt threads on – you can use that to clamp in your vise while you work, then saw them off. I like tools with a final length of either 4.25" or 4.5" long. 3. Draw the rough shape of your tool on the bolt head with a Sharpie. This gives you a rough idea of how much metal to remove on a grinder before you get to the more detailed work. 4. Use a grinder to rough out the outside shape – I do this very rough. I don't try to do any curvature with a grinder (for example, I don't do the bottom of a shader with the grinder). Picture 1 is the tool and the impression when I finish with the grinder. Note it is very rough, and large. The grinder is just for bulk metal removal… but it takes too much off too fast to be used for detail work. http://i109.photobuc...06/IMG_4390.jpg 5. Once you have the rough shape, use a mill file to give you tool shape. I find it easiest to have a finished tool to compare to as I go. Many tools have subtle curves that you don't really notice until you try to make your own. Stamp your new tool into test leather often to make sure you are getting the shape you want. Note the second impression – it is a little smaller, and has a little more shape. This is about the point I stop using the file and go to emory cloth. http://i109.photobuc...06/IMG_4394.jpg 6. Continue to refine the shape. Once you are happy with the rough shape, use coarse emory cloth to put the final shape to it. Impression #3 is about the point at which I stopped using the coarse emory cloth. The scrap in the picture is to give you an idea of how often I am testing the stamp as I go. http://i109.photobuc...06/IMG_4395.jpg 7. Continue to refine the shape - use medium emory cloth then 600 grit to work out the grinder and file marks. Impression #4 is taken while I was using the medium emory cloth. See how much smaller the stamp is getting? Don't take too much off with the grinder… it is easy to make a tool smaller, but you can't make it larger! http://i109.photobuc...06/IMG_4396.jpg 8. At this point, I will clean up the tool and take it to my bench and do some testing with it. Typically, that leads me back to step 6 with the coarse emory cloth. Repeat as many times as necessary (hey, nobody said this was simple J). Impression #5 is taken while I was working with the 600 grit paper in the testing stage. See on the face of the tool – you can see very fine marks that I haven't worked out yet – I will work those out too. http://i109.photobuc...06/IMG_4398.jpg 9. Once you like the shape, use 1500 grit wet/dry sandpaper to put a nice polish on it. Then I put the smooth tool to use and make sure it walks if it is a walking tool, and just generally make sure it is going to work. http://i109.photobuc...06/IMG_4399.jpg 6. Then polish with a rag wheel on a bench grinder (I use rouge for stainless first, followed by a different wheel with white rouge on it). Then it is time for the lining tool. On this tool, I am using a 75 LPI file from Brownells (www.brownells.com). I try to get one end of the tool face, then line it up and get the other end of the tool face. I use magnifying glasses to get the lines lined up after I have run the file across the face once. It is tough to line them up, and takes practice. Don't be afraid to file off the lines and start again. The good news is that, even it isn't perfect, nobody will notice on your leather! I studied one of my good tools from a custom maker under a magnifying glass, and the lines aren't perfect, but you can't tell that in the stamp impression. http://i109.photobuc...06/IMG_4400.jpg 7. Then back to the scrap, to test some more now that the lining is done. http://i109.photobuc...06/IMG_4402.jpg 8. Once you are happy with it, take a fine brush and some household cleaner (even a tooth brush) and clean out any filings, and clean up the metal dust. Then cut the tool to the right length with a hacksaw and clean up the rough end. Do some final polishing, then you have your finished tool! http://i109.photobuc...06/IMG_4403.jpg 9. Here are a few tools I have made. There are a couple of leaf liners, a small and a medium thumbprint, a set of fine bevelers (75 LPI) and a set of coarser bevelers (50 LPI), and a veiner. http://i109.photobuc...06/IMG_4404.jpg I will probably put these tools on E-bay over time, so if anybody wants any of them, let me know. Hope this is helpful. Have fun… jump in and start filing – that's the best way to learn. aaarrrggghhh! Can't access the photos from this tutorial. Have they been moved to someplace else??? Am I too late??? Thanks. Quote
Members WyomingSlick Posted January 10, 2010 Members Report Posted January 10, 2010 I am just getting into messing around with stainless steel on my metal lathe. About stainless steel; It is an alloy containing iron like all steels. And like them, it will rust - unless you "pickle" it; which consists of placing it in a weak nitric acid bath which eats away the surface iron so there are no iron particles left on the surface to oxidize. Both of these were made from solid SS rods. I have picked up some SS bolts and mean to try them out for tool stock sometime also. Quote (John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV) And the truth is that religion is nothing more than the lame attempt by largely ignorant people to bring sense and order to a world that was beyond their comprehension. Once you see religion for the delusional and superstitious artifact it is............... you will be free !
Members TTcustom Posted January 19, 2010 Members Report Posted January 19, 2010 Stainless steel differs from carbon steel by the amount of chromium present. Carbon steel rusts when exposed to air and moisture. This iron oxide film (the rust) is active and accelerates corrosion by forming more iron oxide. Stainless steels have sufficient amounts of chromium present so that a passive film of chromium oxide forms which prevents further surface corrosion and blocks corrosion from spreading into the metal's internal structure. For further reading to better understand just what exactly stainless steel is the Wiki article is a good starting point. Quote I am fifty years old and I have always lived in freedom; let me end my life free; when I am dead let this be said of me: 'He belonged to no school, to no institution, to no academy, least of all to any régime except the régime of liberty.' "What we need is more cowbell!"
Members kk1992 Posted February 7, 2010 Members Report Posted February 7, 2010 i don't know alot about leather working, but i do know alot about steel. instead of using bolts, go to a junkyard and buy automotive coil springs. just run a plasma cutter or oxy/acelatene torch down opposite sides of the coil and you have a bunch of really long springs steel blanks for tool making that'll last 4ever. and if you want shorter handlse cut down 3 sides of the spring. depending on the spring itself you can get anything from really narrow pieces to really thick pieces. i use these tools on steel and they last a long long time. i usually forge them out by hand but if you are going to machine them you need to normalize the steel first to soften it. just heat it up to red/ just b4 yellow and burry it in the dirt for a few hours, or for an even softer working surface build a small campfire and a fan, build up the fire, throw in the steel, hold the fan on it, and then take the fan away in walk away. come backa few days later and they'll be as soft as butter. and then to re-harden after tooling heat the steel to a cherry red and drop into oil to quench. stamps made like this will last forever due to the high carbon content of the steel, and they should make good, sharp impressions year after year. hope that helps someone. Quote
Members WESTBOUND Posted April 7, 2010 Members Report Posted April 7, 2010 This is what I have been looking for all over the internet, "How to make leather tools" and I have not found anything. I guess I should have started here. Any updates on new tools and techniques used to make stamps and other tools? Pictures are worth a thousand words, and picture tutorials are worth more than gold..... Please, respond this is a very good and important topic, for me and others. Thanks Quote
Members WESTBOUND Posted April 10, 2010 Members Report Posted April 10, 2010 i don't know alot about leather working, but i do know alot about steel. instead of using bolts, go to a junkyard and buy automotive coil springs. just run a plasma cutter or oxy/acelatene torch down opposite sides of the coil and you have a bunch of really long springs steel blanks for tool making that'll last 4ever. and if you want shorter handlse cut down 3 sides of the spring. depending on the spring itself you can get anything from really narrow pieces to really thick pieces. i use these tools on steel and they last a long long time. i usually forge them out by hand but if you are going to machine them you need to normalize the steel first to soften it. just heat it up to red/ just b4 yellow and burry it in the dirt for a few hours, or for an even softer working surface build a small campfire and a fan, build up the fire, throw in the steel, hold the fan on it, and then take the fan away in walk away. come backa few days later and they'll be as soft as butter. and then to re-harden after tooling heat the steel to a cherry red and drop into oil to quench. stamps made like this will last forever due to the high carbon content of the steel, and they should make good, sharp impressions year after year. hope that helps someone. Would that technique work for other forms of steel easier gotten than by cutting springs out of a junk yard car with a plasma cutter? for example, a piece of steel rod from Home Depot or Lowes? Quote
